DIY: Installation of Magnaflow Exhaust
Old May 14, 2004
Forum Bot's Avatar
Site Robot. Do Not Msg.
Forum Bot has disabled reputation
<h1><font face="Verdana">Required Tools:</font></h1>
<p><font face="Verdana"></font></p>
<p><font face="Verdana">1. Jack</font></p>
<p><font face="Verdana">2. At least 2 jackstands, 4 would be better not to mention safer.</font> </p>
<p><font face="Verdana">3. 14 millimeter open close wrench.</font></p>
<p><font face="Verdana">4. 14 millimeter socket and wrench.</font></p>
<p><font face="Verdana">5. 12 millimeter open close wrench or socket/ socket wrench.</font></p>
<p><font face="Verdana">6. Blocks of wood or extra jackstand.</font></p>
<p><font face="Verdana">7. WD40 or any other penetrating oil.</font></p>
<p><font face="Verdana">8. Safety goggles.</font></p>
<h1><font face="Verdana">Setup:</font> </h1>
<font face="Verdana" size="3">1. Make sure the car has cooled enough to touch.</font>
<p><font face="Verdana">2. Place car on Jackstands</font></p>
<p><font face="Verdana">3. I recommend you were safety goggles before going under car because dirt will fall in your eyes during this install.</font></p>
<p><font face="Verdana">4. Spray boltsconnected to catalytic converter and resonator with oil and let penetrate for 5 minutes.</font></p>
<h1><font face="Verdana">Removal of Stock exhaust system:</font> </h1>
<p><font face="Verdana">1. Using a 14mm wrench or socket, begin removing the three nuts on the rear of the catalytic converter (see red arrows on picture).Depending on the <img height="310" alt="" hspace="0" src="/diyimages/remove_stock.jpg" width="444" align="right" border="0" />
amount of rust, it may be really tight.Keep in mind the top nut is a little difficult to get too.If you have a breaker bar, it will give you leverage on loosening the bolts or even better, an impact gun. Always loosen a few turns on each nut to avoid stripping of bolts.</font></p>
<p><font face="Verdana"><br />
2. Next step is to begin removing the two bolts that connect the stock muffler to the stock resonator in the rear.Use a 12mm socket and wrench and begin removing the tension bolt.Be sure to loosen a couple turns each side. The bolts and spring will come off.</font></p>
<p><font face="Verdana"><img src="/diyimages/stockMuf_stock_res.jpg" alt="" border="0"></font></p>
<h1><font face="Verdana">Remove muffler:</font> </h1>
<font face="Verdana">3. Now that all the bolts have been removed, begin removing the stock muffler from the hangers.Locate the two rubber mounts above the muffler.The <img height="288" alt="" hspace="0" src="/diyimages/remove_hangers.jpg" width="384" align="right" border="0" />
best way to remove this is to remove the rubber mounts from the hangers that are attached to the chassis.Your going to have to work it off the mounts and it will be a little difficult.Just keep pulling.</font>
<p><font face="Verdana">4. Next step is to remove the resonator and piping.Begin removing the rubber mounts above resonator from the hangers.Again, this will be a little difficult just like it was with the muffler.Once you get it off, lower the resonator and pull the rest of the stock piping off.Your stock exhaust should be completely removed.</font></p>
<p><font face="Verdana"><img src="/diyimages/remove_resonator_&_piping.jpg" alt="" border="0"></font></p>
<h1 align="center"><font face="Verdana">INSTALLATION OF MAGNAFLOW EXHAUST</font></h1>
<p><font face="Verdana">1. Now we are ready to install our new exhaust.Install the resonator first by connecting it back to the rubber mounts and attaching it to the hangers.This will make it easier to install the piping (no picture).</font></p>
<p><font face="Verdana">2. Connect the flange to the rear of the catalytic converter and begin to tighten all three bolts until tight or roughly 40lbs of torque.</font></p>
<p><font face="Verdana">3. Place clamp over pipe (do not tighten yet) and connect pipe to flange (pipes slip over each other).With other clamp on the other end of the pipe, connect pipe to the resonator.I used blocks of wood to hold one end in place.</font></p>
<p align="center">
<img src="/diyimages/Connect_the_flange.jpg">&nbsp;&nbsp;&nbsp;&nbsp;<i mg src="/diyimages/Connect_the_flange_pt2.jpg"></p>
<p><font face="Verdana">4. Next, install new muffler on to hanger using old rubber mounts.</font></p>
<p align="center">
<img src="/diyimages/install_new_muffler_on_to_hanger.jpg">&nbsp;&nbsp; &nbsp;&nbsp;<img src="/diyimages/install_new_muffler_on_to_hanger_pt2.jpg">
</p>
<p><font face="Verdana">5. Connect muffler end to resonator.</font></p>
<p align="center"><font face="Verdana"><img src="/diyimages/Connect_muffler_end_to_resonator.jpg" alt="" border="0"></font></p>
<p><font face="Verdana">6. Turn clamps sideways so they are not oiting downwards and tighten. You're finished!!!! <br />
When you first start your car, check for leaks.As the car warms up, your piping and exhaust will begin to smoke.THIS IS NORMAL, it will burn off after 10 or 15 minutes of driving.</font></p>
<p align="center"><font face="Verdana"><img src="/diyimages/end_result.jpg" alt="" border="0">&nbsp;&nbsp;&nbsp;<img src="/diyimages/end_result_2.jpg" alt="" border="0"></font></p>
jcb111
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Apr 17, 2025 12:24 AM
Reverb2005
Jun 26, 2015 06:22 PM
Red_Chaos1
Jun 21, 2015 01:12 AM
bsmiley
Apr 27, 2015 01:27 PM
kanin247
Bolt-on Engine Performance
Apr 25, 2015 05:44 AM
