How To - Fix Headlight Haze
Old Aug 23, 2010
  #31
grendel's Avatar
grendel has a spectacular aura aboutgrendel has a spectacular aura about
Re: How To - Fix Headlight Haze
^ welcome to civicforums!
Old Oct 14, 2010
  #32
nuxil's Avatar
nuxil is an unknown quantity at this point
Originally Posted by Davinci187
Toothpaste with baking soda and an old rag shines lights up great! And its all in the bathroom already
did not try soda but the toothpaste works fine (-:
Old Oct 15, 2010
  #33
kyle_l88's Avatar
kyle_l88 will become famous soon enoughkyle_l88 will become famous soon enough
Originally Posted by lowlife9
go to walmart or autozone and get a 3M headlight restoration kit it come with everything you need.
The 3M headlight restoration kit is AWESOME. I can second that. It costs a bit more, i think like 20 bucks? But im pretty sure you can use it on at least 3 sets of headlights depending how bad they are. Plus its all drill bit based so its ALOT faster and easier on the hands/wrists.
Old Nov 22, 2010
  #34
silver2's Avatar
silver2 is an unknown quantity at this point
Small dab of toothpaste and a wet paper towel...no charge.
Old Dec 31, 2010
  #35
boosted01civic's Avatar
boosted01civic will become famous soon enough
Perfect it Rubbing compound works good. Dont understand why people want to go cheap on clearing headlights up though?
Old May 12, 2011
  #36
civicchick2001's Avatar
CivicChick2001
civicchick2001 is a name known to allcivicchick2001 is a name known to allcivicchick2001 is a name known to allcivicchick2001 is a name known to allcivicchick2001 is a name known to allcivicchick2001 is a name known to allcivicchick2001 is a name known to all
what exactly do you do? apply it to the paper towel and rub it in? or rub it in to the light first, then use the towel to wipe it off? ive never heard of this before.. and also, do you let it sit? or just put on, then wipe off? thanks for any advice.. ( new to this forum thing )
Old May 12, 2011
  #37
toothpaste has abrasives so i imagine you need to be rubbing it in to sand off the haze.
Old May 13, 2011
  #38
CivicChick2001
Hmm.. Well makes sense.. Guess it's worth a shot. It's free so that's a plus and if it doesn't work, I'll go pick up the other stuff that was talked about. Thanks for gettin back to me. Didnt know if anyone would lol.. But yeah I'll try this..
Old May 25, 2011
  #39
johndeerebones's Avatar
johndeerebones is a jewel in the roughjohndeerebones is a jewel in the roughjohndeerebones is a jewel in the rough
I fixed my headlight haze for about 5 minutes time and free. We have a air buffer at work. Used it and some 3m finesse it and polished my headlights up like new ones. No sanding or anything. The only collateral damage was slinging some polishing compound up on the windows. Windex and towels and crystal clear headlights!
Old May 29, 2011
  #40
rjones7755's Avatar
So if i do this the factory seal will be gone and once the polish wears off, i will i have to repeat this process?
Old May 29, 2011
  #41
well that "factory seal" uv protection layer is what caused the problem in the first place. notice that all the damaged lights are from oem lamps that have never been cleaned or protected. the best way is to keep them from going bad in the first place by protecting new lenses with a sealant like wolfgang plastik surface sealer. its pretty much like a wax for plastics you apply every month or two to protect from yellowing. now if yours are messed already, you will have to likely sand the lights to remove the oxidized layer and then polish it to a clear shine. it will never be perfect like new, but close enough. then you still need to use protectant or it will oxidize again over time. it is just the nature of keeping a car outside. sun will damage paint too if its not waxed and taken care of.
Old Jun 6, 2011
  #42
EM2 captain's Avatar
EM2 captain is on a distinguished road
Originally Posted by PiNoY Ep3 SI
Dont know if this is in the right section so mods please move if needed.
ALSO I AM NOT RESPONSIBLE FOR ANY DAMAGED HEADLIGHTS THIS IS JUST A GUIDE.
Tools needed
1. microfiber cloths
2. Meguiars Plastic-x
3. Bucket with a little car wash.
4. 800 grit 1500 grit and 2000 grit sand paper. You can go up to 3000 grit if wanted.
5. Buffer (optional)
6. Blue painters tape.
Here is a before pics of the headlights before i started. The car is my gf's 2001 VW Jetta 1.8T
Before you get started go ahead and put about a table spoon of car wash into the bucket with a gallon of water. Take sheets of sand paper and put then in the bucket and allow them to soak for about 5-10min.
While the sand paper is soaking. start off by masking around the headlights to prevent any paint from being scratched.
Should look like this when finished.
After you have the lights masked off take some soapy water and clean off the headlight. Once clean take your lowest grit sand paper in my case it was 800 grit then start sanding in one direction either up and down or left to right. DO NOT SAND IN A CIRCULAR MOTION. After the 800 grit paper the light should look really hazy and scuffed up.
800 grit
After you are finished with the 800 grit do the same thing with the 1500 but go in a different direction. If you went left to right go up and down.
1500 grit
Once your finished with the 1500 do the same thing with the 2000 and again go in a different direction.
2000 grit
Once you are done sanding take a buffer and apply some Meguiars Plastic-x to the headlight. If you do not have a buffer you can do this step by hand it will take longer but you will get similar results. I only buffed each headlight for about 5min you can get better results by buffing them longer but yeah of course i got lazy. If your using a buffer do not apply to much pressure and dont stay in one area to long because to much heat will cause the headlight to warp.
Once your done buffing take some wax and put a coat on to protect the headlights from hazing up later on.
Here are pics after using the Plastic-x the buffer and wax.
Before
After
If anyone has any questions please feel free to ask.
I've used this product before and it really does work.
Old Jun 10, 2011
  #43
The Meguiars Plastic-x really does work!
Old Sep 12, 2015
  #44
rallyeredem0's Avatar
rallyeredem0 is an unknown quantity at this point
toothpaste works for a few weeks at the most
bug and tar remover works a bit better
nothing beats new headlights
Old Sep 12, 2015
  #45
Sanding and finishing with a uv-protective clear coat spray is a cheap alternative to completely replacing your headlights, though. Did mine and my girlfriend's last weekend
hers:
mine:
I think it cost me... $10 to do both of our headlights, and I have plenty of materials left over. I'm pretty sure I have enough materials to sand down my carbon fiber hood and spray a couple coats of clear to restore it. If not, another $4 for a can of the clear coat should do
Old Sep 12, 2015
  #46
RIPSAW's Avatar
RIPSAW has a spectacular aura aboutRIPSAW has a spectacular aura about
My 2007 Civic were quite dark and glazed. Spent a few hours cleaning them up last year and they came out fairly well but they are still quite dark brown looking. Now they are not so fogged over but they are even darker, almost like the heat and sun has baked them a little too over-done.
I polished and buffed a small area. I can get it smooth and clear again but the dark brown appears to be all the way thru.
Think it may be time for new assemblies? Any thoughts?
I see them on Ebay for about $90 each. Think they will be OK or should I bite the bullet and get them from College Honda when they do the free shipping before Christmas?
Civic has about 106K and I had planned on keeping it another 100 K or till it drops.
Old Sep 12, 2015
  #47
What did you use to clean them up? My girlfriend's headlights were just like that, with a crusty layer on the top that severely diminished light output. I wetsanded with 400 grit to get that crap off, then followed up with 1000 -> 1500 -> 2000 -> 2500 grit, then finished it off with a few layers of UV protective clear, applied over the course of a few hour to make it last. Worked like a charm
usajags84
15
Aug 19, 2015 03:12 AM
carid
Jun 16, 2015 06:40 AM
intensity
May 12, 2015 10:43 PM
shaejb15
Apr 26, 2015 07:44 PM
VNlilMAN
Detailing
Jan 7, 2002 11:23 AM
