Amplifier ground wire
Old Jun 30, 2011
pwnsauce's Avatar
pwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the roughpwnsauce is a jewel in the rough
Anyone have a good ground wire location for an amp in the trunk of a 2004 VP coupe? Right now i have it grounded on a piece of the frame i found on the right side of the trunk behind the carpeting, but my wire is pretty short and there is almost NO slack on it. Pics appreciated
Old Jul 24, 2011
Black_EM2's Avatar
EM2 Owner
Black_EM2 is an unknown quantity at this point
Re: Amplifier ground wire
it all depends where your amp is located. I have mine under the seats on a bolt>Cap>amp
Old Jul 24, 2011
tencc's Avatar
tencc will become famous soon enough
I'm running two amps grounded to a common point. One amp is mounted on the left rear seatback and the other is on the right side of the trunk floor more to the front of the trunk. The grounding point is at the bottom of the front of the trunk cut out where the back seat and the openning of the truink meet. Make sure to remove the paint to get a good metal to metal contact grounding point. Also use at least 4awg power and ground cable and do the "big three" wiring, which is using at least 4awg cabling for your alternator output, battery ground and chasis ground. The reason for the large guage cabling is the amps use alot of current and with the little wire that comes off the stock alt. will put a strain on your electrical system.
hondadriver95
Jul 13, 2015 09:43 PM
Jul 12, 2015 11:54 AM
JUNITO
Jul 9, 2015 08:36 PM
CivicsClass101
Jul 9, 2015 11:14 AM
robbie374
Jul 7, 2015 02:56 AM
