Hey from Bakersfield ca
So I just bought a 2004 Honda Civic lx for 400 it turns on just the owner spun a bearing in the engine
now I got 2 questions is it fixable and two what other civic motors fit a 2004 Honda Civic lx what years can I look for for motors to just swap it out
Re: Hey from Bakersfield ca
welcome
04-05 will be drop in, 01-03 will work after you change a couple parts. you have a non vtec engine so make sure you get a non vtec one
What kinda parts will I have to change is it expensive and can it be done diy and if u were in my situation would u find a drop in one or would u find one t change parts to it and I seen it’s a d17 motor what am I looking for
04-05 have egr and use a different primary o2 sensor (a more expensive air/fuel sensor)
if you buy an 01-03 engine you will have to swap the intake manifold and water housing from your engine to the new engine, and put your exhaust manifold on the new engine.
for piece of mind you should change the timing belt, water pump, tensionor + headgasket, plus associated seals and gaskets. use oem parts you do not want these to fail.
a used engine will be around $200-$500. anything can be done diy, it all depends you, what tools you have, and your abilities. if you know anyone that has done this type of work, bribe them with beer and food to help you.
the current engine probably failed due to burning oil, lack of oil changes/maintenance, so it's probably going to need even more work, but you could keep the parts to use as spares.
buying a used engine is a gamble, but buying from a reputable source that offers a warranty will hopefully mean the engine is decent
alack58
SOHC D17Ax non-VTEC - VTEC Engine Swaps
Jul 11, 2018 04:03 PM
JacquelynB
Sep 17, 2014 09:44 PM
Drachenblut
Mar 5, 2013 02:07 AM
APS
Jul 8, 2002 02:02 PM
