timing belt replacement
Old Jan 28, 2011
rosie's Avatar
rosie is an unknown quantity at this point
is timing belt replacement based just on mileage?
My 2002 has only 60,000 miles on it. I have heard that even with the low mielage the timing belt should be changed because of the cars age.
is this true?
Rosie
Old Jan 28, 2011
TRIZ's Avatar
Re: timing belt replacement
Its going to depend on the condition of the belt. If its cracked and its flexability is outta spec, then you might have to fix the tension or replace it.
Old Jan 29, 2011
Mad Dog Tannen's Avatar
Welcome to the forum.
Inspect the timing belt for deterioration, cracking. fraying, missing grooves, if it still looks new and fexability is good than you are good to go.
Old Feb 6, 2011
rosie's Avatar
thank you
when I open the hood where is the timing belt located? does it have a cover the needs to be removed for inspection?
Old Feb 6, 2011
Originally Posted by rosie
thank you
It's on the drivers side of the engine. You need to take a dust cover off to see it. YOu may need to take off the valve cover depending on your engine.
Dorval Andre
General 7th Gen
34
Jun 3, 2024 08:11 PM
sharp66
31
Jun 12, 2022 08:45 AM
mattdoc
Mar 14, 2017 12:10 PM
bsmiley
Apr 27, 2015 01:27 PM
dano2005
Apr 14, 2015 01:58 AM
