Trunk light not working
Old Apr 24, 2012
jrags's Avatar
jrags is an unknown quantity at this point
So my trunk light isn't working. I put the bulb from the license plate in the trunk and it wouldn't light (tried inserting it the opposite way as well and tried the second light).
I thought maybe it could be a fuse. But I think it uses the same fuse as third brake light. The third brake light (located in the rear deck) doesn't work when it's plugged in. But the spoiler brake light works when plugged in.
The license plate lights work obviously.
Any idea what the issue could be? Maybe something to do with the latch? or wiring. or maybe still a fuse..?
Old Apr 24, 2012
CraigW's Avatar
Re: Trunk light not working
If the car is on and the trunk open...do you get the red open indicator on dash ?
What year ??
Old Apr 25, 2012
jrags's Avatar
Sorry I forgot to mention year and model. It's a 2002 EX coupe.
No, since I got the car a few months ago there has been no light on the dash. Is there supposed to be?
Old Apr 25, 2012
maxtierney's Avatar
EM2ti
The CHMSL (third brake light) shouldn't light up if you have a spoiler light. You may have a sticky/worn trunk latch. Move the little "tooth" in the latch in the trunk with a car key or screwdriver. The light should come on.
Old Apr 25, 2012
maxtierney's Avatar
EM2ti
The red light on the dash will only come on with the engine on and trunk open.
Old Apr 25, 2012
jrags's Avatar
Got it working. Thanks guys.
I ended up just playing with the latch. After figuring out how it worked I was eventually able to get it working. Now the trunk light turns on as well as the dash light when it is open.
Old Apr 26, 2012
maxtierney's Avatar
EM2ti
Glad you got it working.
ORskier
May 3, 2015 12:54 PM
Linda0818
Apr 23, 2015 11:30 AM
cperez53
Apr 16, 2015 09:31 PM
wawacito
Nov 5, 2001 03:32 PM
meels808
Nov 5, 2001 09:15 AM
