OEM Fog Lights Wiring Harness?
Old Mar 27, 2012
krudmuphin's Avatar
I have a 2005 EX Special Edition USDM
Does anyone know if the car is manufactured with the OEM Fog Light wiring harness already in place? Otherwise there will have to be a lot of work to get the wiring into the car. Some cars are built with great modularity and already have wiring harnesses in place despite not all of them having fog lights.
Is this true on 04-05 Civics? Does anyone have experience installing OEM Fog Lights on a 7th gen that could help?
I've already looked under the front bumper, but I did not see any evidence of wiring to the lower corners.
Old Mar 27, 2012
bryan.0831's Avatar
bryan.0831 is an unknown quantity at this point
Re: OEM Fog Lights Wiring Harness?
As far as I know, our cars doesn't come with it out of the factory.
Unless it came with fog lights already.
When you buy the OEM kit, it comes with the harness and instructions I believe. I don't remember. Do not buy cheap or ebay ones, their harness is nothing compared to the OEM. OEM is so much easier to install in my opinion.
Old Mar 27, 2012
krudmuphin's Avatar
Okay, looks like I'll have to set aside a good long weekend or find a body shop that's willing to dig into the car quite a bit. The lights I have are Vinjet brand and are labeled as OEM. To me, the wiring harness in the kit looks nearly identical to the one in the official Honda fog light installation instructions I found online.
I'll probably have a professional do the installation if it involves all the panel work described by the manual. The trick is finding a place that will do it. The Honda dealership rejected it right away claiming they will NEVER install aftermarket parts for any price. Weird... because OEM is technically not aftermarket... I know some 04-05 were sold with the same fog lights.
Old Mar 28, 2012
GolNat's Avatar
Prelude Owner
Don't use the OEM harness it's harder. Gearbox made a DIY. Just read this it will tell you what you need to do.
https://www.civicforums.com/forums/1...-ignition.html
Old Mar 28, 2012
TFMEX's Avatar
CO&CA
TFMEX is a jewel in the roughTFMEX is a jewel in the roughTFMEX is a jewel in the rough
I got ebay foglights and it took me an hour to install them and cost me 35$... VERY easy. as posted above you can DIY.
I have had mine in for 3 years ZERO issues.
Also for the 04-05 civics, the fog lights were not even an option as told to me by the dealer. Even if you wanted them they were not available which I thought was odd.
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
CarStuff
Dec 6, 2020 12:52 PM
Jon-Ohio
Jun 30, 2018 08:10 PM
Shabba
May 13, 2015 10:55 PM
klam
Nov 16, 2001 03:36 PM
