Issue with High Beams
Old Aug 20, 2011
nashvillerider's Avatar
nashvillerider is an unknown quantity at this point
I hope this is the correct section to post.
I seem to have continued bad luck with headlamps on my Civic
A couple of months ago one of my hi-beams went out but I just kept forgetting that I needed to buy a new set. Finally the 2nd one went out and I ordered a new set on eBay. If you can't trust eBay, who can you just. Right??
So my son installed the new bulbs, verified that the old ones were blown and turned on the lights. Nothing!
We looked in the owners manual for a fuse that controlled the hi-beam, but couldn't find anything.
Can anyone tell me what might be wrong? I find it hard to believe that a set of bulbs straight out of the box could be bad?
Thanks in advance for any and all help.
Old Aug 21, 2011
CraigW's Avatar
Re: Issue with High Beams
Need info on car.
Old Aug 23, 2011
Sorry about the lack of info!
2004 Civic. 2dr coupe. 172,xxx miles
Old Aug 24, 2011
CraigW's Avatar
With headlight switch on you should have voltage at RED/YEL on drivers side and RED on passenger. Your ground path and switching of the high beam is on the RED/BLU leads (both sides) via headlight switch high beam circuit.
I would ohm out the new bulbs just to be sure they are o.k.
intensity
May 12, 2015 10:43 PM
speedracersong
Jan 27, 2002 06:28 PM
tcneo
Jan 24, 2002 06:19 PM
BoSS
Nov 27, 2001 04:55 PM
klam
Nov 19, 2001 05:46 AM
