park/clearance light
Old Mar 15, 2011
wyred88's Avatar
wyred88 is an unknown quantity at this point
Hi,
any idea on how to turn off the park/clearance light completely of 2005 honda civic. i have fog lamps and i want that only to light up instead of the park lights. thanks!
Old Mar 15, 2011
Re: park/clearance light
well the park lights are controled by the headlight switch and can turn off anytime. i assume you mean you want to be able to use the fogs without any other lights on. in which case it requires some rewiring of the switch by testing all the wires to find the one that only gets power when the headlight is on. it should be a thin wire, not a thick one. just gotta try them all to find the right one, assuming its oem honda fogs. ebay kits im not sure how its wired. once you find the "headlight trigger" wire, just cut it and attach the switch side to an alternate power source like the 12v socket. that way you can turn em on alone when the key is in ACC position.
Old Mar 16, 2011
wyred88's Avatar
Thanks but i think i have the ones from ebay.
MyCivic
Electrical
Oct 28, 2021 11:06 PM
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
werdnahall
May 17, 2015 11:37 AM
davidarenberg
May 16, 2015 08:45 AM
klam
Nov 16, 2001 03:36 PM
