Foglight Mod
Old Feb 10, 2011
bly's Avatar
bly
bly is an unknown quantity at this point
Foglight Mod
I have been trying to modify my foglights so they can turn on with or without my lowbeams on.
I have took off the top cover to find the clip for the combination light switch and cut the red/yellow wire, then used a fuse tap to get a constant 12v whenever my car is on from the radio fuse.
Now i can turn on my foglights anytime but my fogs still cut when highbeams are used and whenever i put down my handbrake and the drl comes on. for now i pulled the fuse to the drl but would like to figure out how to fix this issue because it is illegal to drive without drl in canada.
Anyone know why my foglights still cut with drl and highbeam? thanks
Old Feb 10, 2011
mc670's Avatar
mc670 is an unknown quantity at this point
Re: Foglight Mod
tap the wire into the 12v fuse for the cigarette lighter in the fusebox, thats what i have done to mine and its been working perfectly like that for a year now..
Old Feb 10, 2011
bly's Avatar
bly
Re: Foglight Mod
i think i have the right idea with what to use as a 12v+ tap but where did you connect it to. I have been trying to find my foglight relay but i cant seem to find it.
Thanks
Old Feb 28, 2011
mc670's Avatar
Re: Foglight Mod
i bought this little plugin clip thinger (dunno what you'd call it.. found it at canadian tire) that clips onto the fuse and soldered the wired it to that. works perfect
UltraHDGames
Jun 8, 2016 05:16 PM
ricer_em2
May 11, 2016 08:09 PM
kmarcet
Sep 26, 2015 10:25 PM
ZoSoIV
Sep 17, 2015 07:17 PM
muniorbust
33
Aug 31, 2015 08:59 PM
