Headlight Trouble
Old Oct 30, 2009
Chrisn's Avatar
Chrisn is an unknown quantity at this point
Headlight Trouble
2005 Civic
I discovered today a burned out passenger side headlight. I replaced the bulb and the light still didn't work. I checked the fuse and the light still didn't work.
Any idea what could be wrong?
Old Oct 31, 2009
CraigW's Avatar
Re: Headlight Trouble
Was the old bulb open or is it o.k. ??
Which bulb high beam or low ??
You could try gently moving the socket/connector while the problem bulb should be on and watch for it to flicker or try to work.
Old Oct 31, 2009
check voltage at the connector.
Nalmonte
Sep 28, 2015 01:10 PM
Bruce2
Sep 27, 2015 08:45 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
