HID & K2Motor Foglight Question
Old Mar 17, 2009
schreibers's Avatar
schreibers is an unknown quantity at this point
So i've been looking at putting a HID's kit in my 05 Civic Coupe. I know there are both single and dual types depending on if you want separate hi-beams or not. I've seen other 4300K setups and I've been impressed with their output.
My idea/question is: I was thinking is could I just solder extensions to the wires going to the OEM high beams and use those wires to power my OEM style K2Motor foglights? I wouldn't see why you couldn't to be honest but I figured i'd check with the guru's here. Saves installing the harness and switch by using the existing high beams switch, fusing, and wiring.
Thanks!
Old Mar 18, 2009
electric130's Avatar
Re: HID & K2Motor Foglight Question
are you wanting to power the low, high and fogs all at once? if so, the stock wiring wouldn't handle that. you'd be trying to put 30A on an 18ga wire. 30A needs a 10ga wire. even if you're wanting to run the highs and fogs together....still too much for stock wiring. the only way around it is with a relay harness off the battery.
tuvok
Sep 25, 2015 03:13 PM
JMKendrick
Sep 16, 2015 06:17 PM
junkyardguy
Sep 2, 2015 06:07 PM
herbiej
22
Aug 23, 2015 01:02 PM
martinsmartin
Aug 15, 2015 07:34 PM
