2004 Civic High/Low beam adjustments
Old Jan 14, 2009
sshobert's Avatar
sshobert is an unknown quantity at this point
I see the Up/down adjustment printed on the inside right/left corner of headlight asssmblys, along with right/left adjustment printed on the outside upper right/left of the assemblys. What i do not see are the adjustings screws?? to make adjustments. HELP
Old Jan 15, 2009
Re: 2004 Civic High/Low beam adjustments
if you have sedan, you have both adjustment wheels (but the left/right is covered with plastic and should not be adjusted). coupes only have the up/down. you can stick a star screwdriver through the frame and into the top of the gear to turn it, thats the easiest way. or use a socket and turn it that way. but screwdriver is easiest. the manual explains it also
gearbox
Electrical DIY
72
Nov 27, 2015 08:13 PM
chgofirefighter
Apr 18, 2015 08:08 PM
GH04si
Apr 15, 2015 08:13 PM
Elusiv1
Nov 8, 2001 09:55 PM
