HID Plug and Play Kit install
Old Aug 9, 2007
blazed870's Avatar
blazed870 is on a distinguished road
Hey everyone, I just got my ebay plug and play HID kit. It is a H4 6000k kit that I plan on installing in my 02 lx sedan with stock headlights.
I was searching for a DIY, but unfortunately I couldn't find one. I have taken pictures of the kit. These are the first 3, but I took about 17 more with all the parts up close.
Can someone help me out with the installation process?
Thanks in advance
ID:	72218   Click image for larger version
Name:	HID Kit Box inside.jpg
ID:	72219   Click image for larger version
Name:	HID Kit Box outside.jpg
Old Aug 10, 2007
chawski's Avatar
chawski will become famous soon enoughchawski will become famous soon enough
Re: HID Plug and Play Kit install
you bet. the wire with the red stripe around the end is your power wire. Attach this to either the positive terminal of your battery or to an open fuse in the box right behind your battery. the 2 long wires with the amp connectors go to both ballasts. there is also a ground on each on of these. attach that to the screw on top of both headlights or get some self tapping screws and attach it to somewhere on the chassis. plug your harness into one of the stock plugs. if you are looking at the stock plug so the holes are in the shape of a triangle, your slot on the right is your 12 volt source, the one on top of that is your low beam ground, and the one to the left of your hot wire is youre hi beam ground. plug the amp connectors on the bulb to the corresponding amp connectors on ballast. check that everything lights and throw em in the housings. hope this helps, lemme know if oyu have any more questions
Old Aug 10, 2007
electric130's Avatar
the bottom terminal with the red sleeve goes to the battery. the two connectors off the main harness with the yellow gasket go to the ballasts. the ring terminal off these gets grounded. the last connector is the problem. from your first pic, it looks like a 9006 connector, not an H4 connector. seing the same type of connector off the bulbs, it looks like you got a 9006/9005 harness, not an H4 harness. the bulbs look to be low beam only though, so as long as the base is H4, then you'll be fine. you just need to either put an H4 connector on there or you could just go with some spade terminals. this is where i got my H4 connectors when i made my harness:
http://www.comagination.com/parts.htm
Old Aug 10, 2007
LT2004ever's Avatar
I wil fix vBPlaza today
no general instructions came with them?
nice job helpin chawski +rep
edit: i cant rep either of u
Old Aug 10, 2007
oh yeah, if you are using the low beam only, that rubber boot with the black and blue wires can be removed and so can the wires. you won't need them. that's if you were putting these bulbs in a housing that had a seperate high beam.
Old Aug 10, 2007
chawski's Avatar
like electric said, the easiest way to use this harness with an h4 plug is just to pull the 9006 (or whatever is on it) off and just use a simple spade for your power and ground. they cost like 99cents for a pack of 6 at home depot.
Old Aug 10, 2007
blazed870's Avatar
Thanks for all the help guys.
From your instructions, this is what I have....
Does this look correct to you?
So they gave me the wrong wire harness? Is that something I could buy at a local store, if so what type of store?
I have also attached up close pictures of the two terminals circled in the picture.
Old Aug 10, 2007
blazed870's Avatar
They came with some general instructions and for the most part I could figure out how they went together. My biggest question was how to plug the wire relay in since the plugs didn't match. Thanks electric130 and chawski for the help on clarifying that.
Old Aug 10, 2007
blazed870's Avatar
Here are the wire relay pictures, sorry I had to resize them.
Name:	Relay harness plug 1 up close.jpg
ID:	72229   Click image for larger version
Name:	Relay harness plug 3 disconnected.jpg
ID:	72230   Click image for larger version
Name:	Relay harness plug 3 wires 1.jpg
ID:	72231   Click image for larger version
Name:	Relay harness plug 3 wires 2.jpg
ID:	72232   Click image for larger version
Name:	Relay harness plug 3 wires 3.jpg
Old Aug 10, 2007
chawski's Avatar
this plug goes to your ballast. thats your power supply
Old Aug 10, 2007
blazed870's Avatar
Sorry for the bad picture, that close up is of the right circled plug on the relay with the notes I made. There is only one of those. So that is the plug that should be the H4 plug(but in this case it's a 9005/9006) that I plug into my stock plug? Thanks again
Old Aug 11, 2007
chawski's Avatar
yup looks like it (cant tell 100% from the blurriness). youre gonna need to cut that off and put on spades on your positive and negative and plug them into the stock h4 harness
Old Aug 11, 2007
blazed870's Avatar
That plug has a black wire and a white wire. Which one is my hot and which is ground?
Old Aug 11, 2007
chawski's Avatar
black is generally universal for negative
Old Aug 11, 2007
yup. black is ground and white is positive. you can either cut it off and put some male spade connectors on there, plug it in to your stock wires and put some electrical tape around it to prevent the power grounding out to some metal, or you can put a male H4 on there. the latter is what i did, then put some dielectric grease on the connection to keep water out. oh, and you'll only use one of your stock headlight connectors if you didn't figure that out. the other one i just tied up out of the way so it wasn't flopping around.
Old Aug 12, 2007
blazed870's Avatar
Thanks again chawski and electric130. I had planned on doing it this weekend, but I ended up working O.T at work. I was thinking of just doing the spade connections, but I was kind of worried about shorting them out. I think I will go ahead and order the male H4 plug, or maybe the vendor will send me out the right one. I will post pictures once I complete them, even though you guys have probably already seen them 1000's of times.
Old Aug 12, 2007
no, post pics by all means. it's always cool to see new results.
Old Aug 13, 2007
blazed870's Avatar
It might not be until this weekend, the vendor I bought them from is sending out the right wire harness.
Old Aug 31, 2007
mani_is_kool's Avatar
mani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nicemani_is_kool is just really nice
^^ who did u buy em from that kit looks familiar :d
97-DX-Lover
Jun 14, 2015 06:07 PM
JohnnyBxo
16
May 9, 2015 05:53 PM
Maximus
Bolt-on Engine Performance
Nov 14, 2001 10:52 AM
SneakerPimp
Nov 3, 2001 10:57 AM
