HID install question
Old Feb 10, 2007
parmo's Avatar
parmo is an unknown quantity at this point
hello every1. im sure this question has come up before in these forums, but i couldn't find it using search. anyways here it goes. im trying to install an HID plug and play kit using my oem lights. where is the best place to mount the ballasts? (i.e. is there room underneath the headlights, or do you simply mount it in the engine bay)
if in the engine bay where is the best place to mount it, if someone has had experience doing this install any help would be greatly appreciated, as well if any1 has pictures of the ballast install that would be great
lastly, if there is space underneath the headlights, can you use double sided 3m tape to mount them?
thanks in advance
-parm
Old Oct 17, 2007
Kevbotron's Avatar
I like my commute
Re: HID install question
ing this back to get an answer.. just got these in the mail
thoughts?
Old Oct 17, 2007
KCblackVP's Avatar
KCblackVP will become famous soon enoughKCblackVP will become famous soon enough
Where did you get that kit from man?
Old Oct 17, 2007
Kevbotron's Avatar
I like my commute
a member on here.. 65 bucks shipped!
Old Oct 17, 2007
KCblackVP's Avatar
Cause that looks identical to the kit I got off here except I never got the relay harness to power up the ballasts. And from what I can tell you didn't either? Am i wrong, is there a different way to install them cause when I hooked what seem to be everything up into its correct plug ins nothing happened. I took it to a local shop and they said I needed a relay harness?
Old Oct 18, 2007
Kevbotron's Avatar
I like my commute
yeah I bought a relay harness for it.. I'm thinking about mounting it under the upper fenders.. Seen that done before..
Anyone have any pics where they mounted theirs??
Old Oct 18, 2007
Devani's Avatar
Devani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond reputeDevani has a reputation beyond repute
I put the Driver one below the headlight(Right under it)
...pass one hebind the headlight(between battery and headlight)...
Old Oct 18, 2007
Kevbotron's Avatar
I like my commute
^ got a pic? did you drill holes in the frame?
Old Oct 23, 2007
electric130's Avatar
my low beam ballasts just sit in the engine bay. one between the battery and the relay box, the other just behind the driver headlight. not really mounted, just sitting there held in place with zip ties. now my fog light ballasts are both behind the bumper and they're bolted to the car.
Old Oct 23, 2007
Kevbotron's Avatar
I like my commute
^thanks for the info.. I'm doing the install this weekend, got the harness in the mail.. It's the one that draws power from the battery directly.. is that the best way to draw the power?
Old Oct 23, 2007
chawski's Avatar
chawski will become famous soon enoughchawski will become famous soon enough
thats exactly how ive had mine with no problems.
masongap
May 26, 2015 07:55 PM
Rogelio Rey
May 24, 2015 08:30 PM
terry_tr6
HIDs and Retrofitting
May 16, 2015 08:37 AM
