HID help....
Old Oct 18, 2006
HondaKorn's Avatar
Life is better with 5lug
HID help....
I got the idea of using oem ballasts and bulbs from a member here as an alternative to cheapo kits....but I have a wiring issue.....I purchased the H4 relay wiring from the link u posted and I wired them up, but the lights come on on even if the car is off. For example I wired the driver's side up (to test)and connected the red power wire to the + battery and black to chassis and they came on.....now, is that b/c I combined all of the grounds for both the harness and ballasts and combined the +'s for the harness and ballasts?? Thanks alot if you can help...they are 350z ballasts and phillips d2r bulbs.
Old Oct 18, 2006
gstyle's Avatar
gstyle is an unknown quantity at this point
Do you have a fuse on the relay? Sounds like that might be gone. That was my problem. Good luck
Old Oct 18, 2006
HondaKorn's Avatar
I will look and check that out...thanks!
Old Oct 21, 2006
HondaKorn's Avatar
I fixed it...I wired it incorrectly....I wired to the white high beam wire...lol
UltraHDGames
Jun 8, 2016 05:16 PM
LilNic13
Nov 28, 2015 10:26 AM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
MamaBear2015
Sep 4, 2015 09:04 PM
