Help me So I Can See!!! at nite that is!!!
Old Aug 31, 2006
Emoral's Avatar
Emoral is an unknown quantity at this point
ok the problem i am having is that only the lowbeams work on the headlights.fuses and bulbs all check out.......what else could it be?!?!?
Old Sep 1, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
switch
Old Sep 1, 2006
do you have an 01-02 civic? there is a recall for the headlight switch. but usually its the lo beam that doesnt work. have you checked the bulbs?
Old Sep 1, 2006
crazyasian's Avatar
crazyasian will become famous soon enoughcrazyasian will become famous soon enough
hey i got a similar problem with having no low beams. i hit a major bump and after that the low beams stopped working. i have hids on valeos and could it be possible that both ballast got knocked off loose and pulled off the connections? i cant check it right now b.c its dark(obviously). i checked both fuses #20, the small yellow fuses in the engine bay. not sure wat else it could be. it might be that some wiring got knocked off or is really wet b.c we had a major flood here and i had to turn around and to do that i had to go in the water which was sorta deep and get bak around. i wasnt in it for too long mayb 2 secs. any ideas guys? only real thing i can think of is that something got knocked loose. and yes both lowbeams arent workin. everything else works such as parking light, highbeam, and my CCFL halo rings.
Kape
Feb 28, 2003 10:14 PM
nymbus2k
Jul 24, 2002 03:36 AM
TopFuel
May 25, 2002 10:10 AM
the1sthotboy
Mar 2, 2002 09:18 PM
