Dual Projectors
Old Aug 24, 2006
thefever's Avatar
I need a drop
thefever is a jewel in the roughthefever is a jewel in the roughthefever is a jewel in the rough
Dual Projectors
Alright, I searched for this, but didn't come up with any results that helped me out alot. Has anyone ever bought the ebay dual projectors? I'm thinking about getting some. I just need to know if I get them, Would I have to run seperate low and high beams? If I did have to run seperate low and high beams, how would I go about doing this. I'm a newbie at lights, so I'm not too sure how this all would work. Any input on this would be greatly appreciated.
Old Aug 30, 2006
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
unless you have found something that is hidden under some weird name or isint listed anymore... my guess is you are talking about the dual halo projectors...
its a single projector bulb for the low beam and a h1 or something NONprojector for the highbeam.. you either use yer stock bulbs or it comes with the high bulb.. i dont remember.. the dual part is the DUAL halos.. not 2 projectors..
plug and play... just tap yer parking lights for the halo.. no you dont need anything more than wirenuts and electrical tape for this
Old Aug 30, 2006
thefever's Avatar
I need a drop
****, I see what you're talking about. I don't know what i was thinking with that title.
Old Aug 30, 2006
but ya for the two bulbs, it already comes with a conversion harness you just plug them in.
Old Sep 1, 2006
againifall's Avatar
Go Team Venture!
i ordered my second set of these lights today... personaly i friggin love them.. i had my first set in for almost 2 years.. never had any fogging or anything... i hope i have the same luck with the second set... true i did seal the first set myself.. but.. whatever..
Old Sep 1, 2006
hey i can send you some led if you wanna redo the halo lights a different color. i have 5mm led in white, blue, green, amber, orange. i noticed the ebay lights are only resistored to 12.5v and will burn out alot faster when car is running. also you should wire them so they ground out (turn off) when the headlights are on because heat also kills them.
Old Sep 2, 2006
againifall's Avatar
Go Team Venture!
mmmm good call on the ground.. yer so smart
Old Sep 2, 2006
if you need to know the color of the headlight 12v, i think its red on one side and red/yel on the other. its in my retrofit diy in lighting forum. so just hook power to the led to the parking light power, and then put the ground on the 12v headlight power. it will come on and stay on with park lights, but ground out when headlight is on.
Old Sep 2, 2006
againifall's Avatar
Go Team Venture!
gotcha
wingsfan19
Oct 1, 2015 03:45 AM
tuvok
Sep 25, 2015 03:13 PM
Mad Dog Tannen
Sep 12, 2015 12:48 AM
