adjust headlights?
Old Aug 27, 2006
cwo715's Avatar
Falken Master
cwo715 is just really nicecwo715 is just really nicecwo715 is just really nicecwo715 is just really nice
adjust headlights?
i got my HIDs in and they are low... how can i adjust the headlights to aim them? Gearrboooox?
Old Aug 27, 2006
7thGenerasianCivic's Avatar
OE headlights? Search?
Old Aug 27, 2006
Honda_Inspired's Avatar
Honda_Inspired is an unknown quantity at this point
There is an oval slot on the top of the headlight; just just a phillips screw driver and turn either counterclockwise or clockwise. I don't remember which way it is to make it higher but you should be able to find out.
Old Aug 27, 2006
FALKEN's Avatar
Civicforums Junkie
they shouldnt be misaligned if all you did was installed new bulbs
if you really feel that you need to realign them...read your manual
Old Aug 27, 2006
most hid kits do not fit exactly like halogen to give the same beam, except catz maybe. so its likely the bulb is producing different optics due to being in the wrong position. stick screwdriver in from the top of the frame and turn this gear.
Old Aug 27, 2006
mikem317's Avatar
mikem317 should not be trusted
I had to lower my beams. When I first installed my HID system, I was getting flashed by every other driver. After lowering the beam significantly, I'm only getting flashed once in a great while (perhaps two or three times since adjusting them).
Old Aug 27, 2006
FALKEN's Avatar
Civicforums Junkie
well, i didnt need to change the setting after i installed my HIDs...
i must have received a well made set
Old Aug 28, 2006
cwo715's Avatar
Falken Master
gearbox how bout on an 04-05 civic head light?
Old Aug 28, 2006
buckshizzo's Avatar
buckshizzo is a jewel in the roughbuckshizzo is a jewel in the roughbuckshizzo is a jewel in the rough
same adjustment for an 04-05 headlight.
Old Aug 28, 2006
ya just look for a hole in the metal frame that you can stick a screwdriver into and turn a gear. should be the same type of gear.
Tedverseti
Sep 29, 2015 05:41 PM
rovafa2002
Sep 28, 2015 06:57 PM
mnewcomb
Air Conditioning
Sep 26, 2015 11:02 PM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
