How do i wire my m3 mirrors
You Stay Classy, San Diego
Ok here is my situation. I have my m3 mirrors installed and my wires ran into the interior of the car. My led colors are blue and white. I would like to wire my blue to a switch so it can be turned on or off at any time. I would also like to wire my white leds to the turning signal. Is that legal first of all to have a white blinker for turning? so anyways i have a switch for the blue ones but my first question is where do i get power for the switch. Im not 100% where to get my 12v dc power. I know i can get it from the fusebox but how. I also know that for the white I i just ground the black and splice into the turn signal but to get to the engine of the car from the cabin do i need to drill through the firewall on the drivers side? Any help would be appreciated
white turn signals are generally illegal, but as long as it isn't blue, purple, green, etc then 99% of cops dont care. White is better, much better, than anything but amber.
As for wiring, just get +12v and ground from the cig lighter wires. Add a switch on either of them, then run to the + of the blue lights, and ground for blue lights.
To wire up the white leds:
Can anyone remember if the turn signals are switched ground, or switched +? If its switched ground you have some wiring work cut out for you (and you need relays). If it's not then this will be easy.
