M3 power mirror wiring help!!!
Old Dec 6, 2004
fatboy's Avatar
fatboy is an unknown quantity at this point
Question M3 power mirror wiring help!!!
OK, I have searched for hours with no luck. I already have the mirrors mounted, all I need is to hook up the wires. The M3 mirrors came with the following:
Motor (3 wires bundled together):
BLACK
WHITE
RED
LED (3 wires bundled together):
i forget the colors (will post/edit later)
anyways, I tried every possible combo (for the moor part at least) and it is always that I can either move the mirror either side to side, or up and down (but not at the same time). There are 3 wires coming from the door on the original harness. If ANYBODY has M3 power mirrors, PLEASE pop off the tweeter pod and tell me how it is hooked up. THANK YOU!
Old Dec 6, 2004
Fletch's Avatar
Fletch is an unknown quantity at this point
i ran into the same problem with mine, and i ended up just trying different combinations until i got the mirrors to have all their original functions. Unfortantly when i push left or right the mirrors go up and down and when i push up and down they go left or right. but other than that everything is ok :-)
Old Dec 6, 2004
jeffsta17's Avatar
jeffsta17 is an unknown quantity at this point
Get a wiring diagram...I think there is one on this site but then just look up power mirrors and it should tell you which wires do what
Old Dec 8, 2004
fatboy's Avatar
you guys suck. i ended up adjusting them manually. I hooked up the LED though. looks tight
Default_Slayer
Electrical DIY
Dec 4, 2022 07:56 AM
Lopes101
Jun 7, 2015 08:04 PM
Paul Harsze
May 20, 2015 11:37 AM
Dmitri
123
Oct 13, 2005 08:01 PM
huyqvu
Dec 12, 2001 02:43 PM
