projectors w/o HID's??
Old Jun 5, 2006
djrabbi's Avatar
djrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to alldjrabbi is a name known to all
sooo my question is..... will projectors give out as much lighting as the regular stock lamps would with the same low beam (9006 for 04-05).....i heard projectors will be alot better wit HID's.... wats your input on this????
Old Jun 5, 2006
7thGenerasianCivic's Avatar
works great with HIDs, halogen projectors spread the light better but I would be bias to give any further opinions on this topic.
Old Jun 5, 2006
djrabbi's Avatar
i see ur sellin HID's????/ how much
Old Jun 5, 2006
TemjinX2's Avatar
it honestly depends on the lens and reflective bowl. If the lens and bowl is crap, then it can be worse for stock. Generally projectors designed for HIDS output the most light.
Old Jun 5, 2006
eh, halogen projector is okay, plenty of light to see, usually outshines other cars on the road. get some +50 bulbs and you'll be fine. 1800 lumen is 1/2 as bright as hid and brighter than stock.
Old Jun 5, 2006
shmik1's Avatar
ahaa!!! the W pattern, my reason for hating mine. and getting rid of them!
Old Jun 5, 2006
djrabbi's Avatar
can u give me a link........cause i have noooo idea wtf u talkin bout ahah
Old Jun 5, 2006
upgrade wire harness www.suvlights.com
osram silverstar +50, ebay http://cgi.ebay.com/OSRAM-H1-Headlig...QQcmdZViewItem
Old Jun 8, 2006
jay78's Avatar
jay78 is on a distinguished road
so u gone buy new projector headlight? ???
if yes
why not retrofit your stock headlight....and get better light out put ?
Old Jun 11, 2006
djrabbi's Avatar
if yes
yea not point of spendin $300+ on lights where i still need HID's and plus i cant do anything by myself without fuvking it up....
Old Jun 11, 2006
TemjinX2's Avatar
but check out that site, you might be able to find a local retrofitter. But once you have them, you can't go back to halogens. Its literally like night and day.
check this link out. It might give you a better idea in what your going to need to do.
http://www.7thgencivic.com/forums/sh...d.php?t=256214
Old Jun 11, 2006
i used to have hid and i went back. in stock housing, sure there was tons of light, but the white makes it harder for my eyes to distinguish objects, and in rain you might as well turn them off it will look the same. at least with the halogen projector i can see the sides of the road.
Old Jun 11, 2006
TemjinX2's Avatar
just get some blazer fogs and do a hid yellow fogs retro then =P.
I'm in socal so it probably rains like maybe 2wks out of the yr or something.
but i love the fact i can light up 4 lanes on the freeway when i drive by myself at night.
Old Jun 12, 2006
jay78's Avatar
rabbi headlight it self gone cost u around 150.00 or more
u can get retrofit kit for around 350.00 everything.....i know a member on this site who does retrofit for people...and he dont charge lot...let me know if u intresting.......
Old Jun 12, 2006
djrabbi's Avatar
yeaa but i think im just gonna buy the projector ones see how those turn out...... if they bad ill do retrofit..... im gonna put in HID's wit my projectors.... soo ill keep u posted
Old Jun 12, 2006
thats what i did. the light was fine so i left it halogen... they put a ton more sidelight but less front light than stock.
Old Jun 13, 2006
djrabbi's Avatar
does anyone know the brightest 9006 bulb........ link would be GREAT!!!
Old Jun 13, 2006
that must be the worst bulb ever made. i could not find any + version of it. only thing i saw was some LED version but its more for show.
http://www.acurazine.com/forums/showthread.php?t=235526
i guess my advice here would be use a stock bulb and get an upgraded wire harness from suvlights.com that should make them a tad brighter.
Old Jun 14, 2006
TemjinX2's Avatar
DO NOT USE LED BULBS AS YOUR LOW BEAMS. LEDs viewing angle or illuminating angle is signficantly less then halogens. You can sand it to try to compensate but its still not the same. The area your going to be able to illuminate at night is going to be less then halogens. I would say this is even borderland dangerous for daily use.
if you want to use halogens, any cheap $20 4300k walmart bulbs will work. There all the same. i had mtecs for 2yrs and they worked fine. $20 shipped on ebay or anything 4300k is fine.
Old Jun 14, 2006
djrabbi's Avatar
i think im gettin HID's.... 8000K
Old Jun 14, 2006
jay78's Avatar
no no 8000k
dont get anything over 6000k
u cant see $hit......more K = less light....if u go over 6000k then you looking for trouble
Old Jun 14, 2006
well anything after 4300k is just robbing light. the higher you go the less light and the worse your eye can distinguish objects. we like yellow light best. and i posted those leds cause it looked neat. its a good idea for show fogs since you cant see with em anyway.
Old Jun 14, 2006
djrabbi's Avatar
im gettin 8000K HID's...... thanks for all ur help guys
Old Jun 14, 2006
okay hope youre not just getting a kit to slap in the projector cause it will look terrible. even in stock housing will be alot of glare and illegal.
Old Jun 14, 2006
djrabbi's Avatar
hahaha WHAT SHOULD I DO THEN!!! rather then retrofitting
Old Jun 14, 2006
uh retro is really the only way to do it right. cops will pull you over with that kind of color. stock hid is white 4300k. and headlights, even non hid have to be white in color.
Old Jun 14, 2006
djrabbi's Avatar
what bout 6000K.... i found theses
http://cgi.ebay.com/ebaymotors/HID-X...ayphotohosting
Old Jun 14, 2006
eh that would be better, but just think about it. you're gonna also have to change your habits a bit. hid need 5 minutes warm up and cool down period, and alot of kits are junky and produce too much glare, so you may get flashed alot. also if a bulb burns, its gonna cost more than halogen to replace.
Old Jun 14, 2006
djrabbi's Avatar
welllllll im not gettin the projectors anymore.... might just keep HID's...... soo can u find me good HID's then since we both know that i dont know anything bout lights ahaha thanks
Old Jun 14, 2006
well the only real way is to "take" one from an oem car and put it on yours. easiest is getting civic projectors and just swapping them with some from audi a4 or something. you can find full hid lens and hardware for this on ebay for around $300-400. or you can do what someone else here did and put some maxima hid reflector into the oem headlight. the point is you need the bulbs AND lens from a factory hid car. just putting hid into civic headlight lens is a disaster. and there is someone here doing retrofits for cheap maybe hook up with him and see what he can do.
