LS430 Projectors in to OEM Housing
My next project Ls430 projectors in to oem housing......i found one projector still need one more to make a pair...also waiting for my TSX clear lens to do a lens swap......
let me know what u guys think so far......will post more pics tomo...
this motor will under the reflector between the reflector and the housing...then projector will seat on top of this motor so i can make the projector move left to right .......if everything works out the way i want....
Special Thankx to 2k2_civic_ex_4d (Dan) he gone put in to oem housing...and gone help me to make custom bracket to hold the projector....
awesome! can't wait to see the results. also, make sure you know which side projector you need. the LS430 projectors are directional, so if you have a drivers side projector, you will NEED a passengers side projector.
i'm actually thinking of doing a LS430 retrofit into my miata. well...it will be special (think bi-xenon with clear lens and color mod).
yep it got a lit hole under projector....any way i need to get the driver side projector....
making ls430 to bi-xenon is kind of hard......i am gone do the clear lens swap and also waher mods too...
just giving u guy idea how it would look..at the finish line
and here some light out put without lens swap and wahser mods
Originally Posted by djrabbi
i want someone to do mine!!!!!!
Do you own the liquor store, or just work there? Every picture you've ever posted has been from the liquor store.. I'd almost guess that you live there too! LOL
can you give us 7thgen locals nice discounts? I buy a lot of booze around the holidays (basically gifts for people) so a one-stop discount shop would be really nice. Extra booze for all.
i just work for him i can give u some discount when u need anything pm me
and i will tell You how much
but i am in Batavia...if u can drive down here...
Results are looking terrific!
I recently purchased some Halo projector headlights for my car (ebay, $200 with shipping) and they look great when installed but the light output is questionable since
1) I'm a first timer and this is my first actual mod to my car so I'm not 100% sure what type of results I should expect or have gotten
2) The cutoff looks a bit funny but legal and not blinding (did it by measuring 25 feet, distance from floor to center of projector lense and adjusted it
My question for you since you've obviously been playing with projector lenses lately is:
Do the projector lense themselves create a difference in the quality of the light output? is it the housing? the bulbs? or combination mainly?
Because my lights don't look a fraction as great as yours are coming along thus far.
Once again, hats off to you for an awesome job so far, can't wait to see the finished results and fully installed.
usually people who complain about halogen light output from projectors have not aimed them properly. when i got mine, one of the lights was pointing 45 degrees to the right and zero light was on the ground from it. so i had to adjust the left/right beam and also the up/down cause it was also aimed too high. one side came perfect tho somehow. and here this should help.
http://www.7thgencivic.com/forums/sh...d.php?t=266457
also if there is no color at your cutoff line, either the aim is off or you need to mod the projector. You can take them apart and either put some wahsers to move the shield closer to the bulb, or bend the shield back towards the bulb. I did that for my fogs and look.
BEFORE
AFTER
BEFORE
AFTER
[QUOTE=-Vile-]Results are looking terrific!
QUOTE]
answer is........HID projector and the bulb....
only with oem hid parts u can get this kind of cutoff line...
for more info u can log on to www.hidplanet.com
QUOTE]
Styven Szastur
Sep 23, 2015 05:26 PM
pilebuck13
Sep 21, 2015 10:45 PM
h4ldol
Sep 10, 2015 12:25 PM
Mannimarco
Sep 7, 2015 10:01 PM
