Pirate Eyes HIDs - DRIVING ME NUTS
Old Apr 20, 2006
Honda_Inspired's Avatar
Honda_Inspired is an unknown quantity at this point
What's going on guys. Here's the story: 2 years ago, I bought a set of VEROX (not a famous brand I'm assuming) 8000K diamond white HIDS. Before you start flamming me for being an idiot and buying a worthless 8000K, I'd have to tell you that I was a novice at that time with HIDS . After the guy installed it and turned it on, I noticed only one bulb was turning on. I was like DUDE!! what's up with this?? And he said the ballasts are new and need time to break-in or something like that . So he turned off the lights, then turned it back on and finally both lights worked. So..... it's been two years and this intermittent problem still happens and I have to turn off the headlight switch, then turn it back on for both to work, otherwise only one bulb will light up. I don't mind turning it off and on for it to work, but this month, I've been having to do that about 2 times on average and it's driving me nuts. The HIDS still give out very good lighting, I just don't know why one will light up at initial start up and the other won't. ummm Thanks!
Old Apr 20, 2006
rjngo's Avatar
rjngo will become famous soon enoughrjngo will become famous soon enough
well...this is what you get from buying NO NAME brands
Old Apr 20, 2006
lewal's Avatar
lewal has a spectacular aura aboutlewal has a spectacular aura aboutlewal has a spectacular aura about
He wasn't asking for you to be an ***, he was asking for some troubleshooting tips.
Old Apr 20, 2006
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
You do know it's bad to flip the HID's on and off on and off...
Old Apr 20, 2006
yea.... I wait 30 secs to a minute before I switch it back on
Old Apr 20, 2006
7thGenerasianCivic's Avatar
I would say it's the ballasts that are defective. Take it back or get an exchange. FYI turning HID on and off will depreciate the bulb quickly. The HID bulb uses a certain amount of power to fire them up and after the start up it will lower. If you turn then on and off without giving them a break you will damage them permantly.
Old Apr 20, 2006
I wish I could, but the warranty is over. This morning, the bulb that didn't light up started to making flickering and buzzing sounds for like 30 seconds when I turned it on! That same damn bulb didn't light up until I turned it on and off twice. Ahhhh!!! The buzzing and flickering noise sounded like electricity about to spark I toggled the wires a little when it was off and the buzzing sounds stopped. They light up fine from time to time, but this is getting annoying. If it can't be the ballasts, can it be the ignitor? Or even the bulb itself?
Old Apr 24, 2006
TemjinX2's Avatar
first answer if the ballasts are taking power directly from the battery and not the stock harness. If it is, then there's your problem. One might only light up because the stock harness can't ouput enough amps for both ballasts. The flickering might be the bulb dying since you been flicking them twice for 2yrs.
Old Apr 24, 2006
crappy hid + crappy installer idiot well what does that give you. imo, just find a better kit and install it yourself. Even if you manage to fix it by making a new harness, the bulbs are already messed up.
Old Apr 24, 2006
jay78's Avatar
jay78 is on a distinguished road
are using relay or not.....i would use relay if u not using one to get more power to the ballast to turn them on instant..stock wire dont give out enought power to ballast....
your ballst probly bad by now if u wasnt using relay......
try rely see what happned if u haven't
Old Apr 24, 2006
It doesn't seem to have a relay. Just basic plug-n-play from what I see it. Does a relay really help? If it does, can someone direct me to a link or show me how to install it? Major discovery today by the way - I don't think the ballasts or ignitors are bad. I traced it down to one stinking light bulb. The one that always does not light up on the first try, well I swapped the two bulbs from the left and right headlights and the one that never works on the first try still doesn't when it was swapped. ahhhh so complicated. I'm gonna try to get new bulbs. My HID system says "8000K" on the box, is it fine for me to use 4300K bulbs? and will the connections fit with my current ignitor and ballasts??? Thanks for still posting and not leaving me hanging.
Old Apr 25, 2006
looks like you need to make a whole new wire harness. or you can buy and custom rig the one from suvlights.com. main point is to get power directly from the battery. the stock wires are used only to send a signal that opens the relay so power goes from battery to igniter. i'm still not sure its the bulb. maybe the ballast connected first is just getting more power. and yea you might be able to get new bulbs, just make sure its the same kind.
Old Apr 25, 2006
Yea, come to think of it, our stock harness sucks at power output. I'll be ordering a new wire harness with relays and see what happens. I'll update once I get the harness installed. Thanks for the help guys.
Old Apr 25, 2006
jay78's Avatar
make you own relay harness
also u can put 4300k bulbs in if u want....make sure u get the pair...
and make sure the bulb output fits to your ballast....
u can buy the relay from autozone or any auto store....then u gone need 12 to 16 gauge wires......u want to put thicker wire for your battery let me link u
http://www.hidplanet.com/forums/view...r=asc&start=50
i would connect the ballast stright to the battery (the one giving u problem) see if the ballast is working.....some time it can me the ballast go bad cuz ballast wasnt getting enought power.....
Old Apr 25, 2006
Link looks good, but I don't have the time or skills to be doing it myself. The only thing I know about relays are that they are "on/off" switches , other than that, soldering and messing with relays is beyond my realm of expertise.
I'm thinking of getting either one of these:
Choice 1:http://www.suvlights.com/product_inf...roducts_id=112 <--- Gearbox's suggestion: A little pricey, but I guess you get what you pay for.
Choice 2:http://cgi.ebay.com/ebaymotors/ws/eB...3ARTQ%3AUS%3A1 <--- Seems of marginal quality and price
Choice 3:http://cgi.ebay.com/ebaymotors/Harne...spagenameZWD1V <--- Looks okay, except for the fact that the seller lacks some grammar and spelling skills don't know if I can trust a product from someone like that. This product would be my last resort.
What do you think?
Old Apr 25, 2006
jay78's Avatar
here my diy
http://www.7thgencivic.com/forums/sh...94#post3851294
Xuhme
21
Aug 7, 2023 03:40 PM
GolNat
Suspension DIY
May 12, 2022 06:49 AM
Rogelio Rey
May 24, 2015 08:30 PM
Jonas Powell
Apr 16, 2015 11:47 AM
smmahan
Apr 15, 2015 08:17 PM
