help valeo wireharness with relay
Old Apr 3, 2006
jay78's Avatar
jay78 is on a distinguished road
can some one post how to do wiring for valeo ballast to with relay
or using relay with switch ??
cuz i had my ballast connect straight to h4 connectors and looks like i burned them so i might hve to connect them some other way (connect some where else beside h4 connectors where and how?)
thankx
this is how i did my wiring
http://www.hidplanet.com/forums/view...r=asc&start=50
post by tmak and did the lowbeam relay only and didnt work....
i think i connect my wires wrong + to - and - to+
so did i blew my ballast ?
i know i did blew my bulb.
also some 1 can tell me wich wire is + and - on valeo slim ballast plz
here is the same pic as my ballast
Old Apr 7, 2006
jay78's Avatar
infinite no help on this ?
i just bought new ballast got hella 3rd gen one let me know how can i do this..thankx
Old Apr 7, 2006
dirtySAMURAI's Avatar
I log in from time to time
i dont know wiring, sorry. you could ask ocelaris (by e-mail or something. he doesnt seem to check this site too often).
Old Apr 7, 2006
jay78's Avatar
ok thankx dude
Old Apr 8, 2006
82801BA's Avatar
82801BA is an unknown quantity at this point
Man, I wired mine without relay....
Wired ballast to positive (the black wire on the low beam TYC wiring that is paired with the blue wire) and put it ground to chassis. The high beam is wired from positive battery and ground to the TYC red wire....The blue wire and the black wire (on the side of red) are taped.....Both Hi/Low beams works, the only thing is when headlight is off, don't PULL the stick to get high beam.....push the stick when the low beam is off will cause only the high beam on without any other lights...
Old Apr 10, 2006
jay78's Avatar
i had mine setup with stock harness but afer 5 months my ballast went bad cuz ballast wasnt getting enought power so it when bad on me,,,,and also i cant turn my hid on rightaway after turning my car on....cuz it was making my lights blinks like strobe light...
with relay i can get more light output
my ballast wont go bad
and wont burn my stock harness.
Old Apr 10, 2006
82801BA's Avatar
I will eventually make the harness anyway....Currently using 20A fuses on the stock line...
Old Apr 11, 2006
jay78's Avatar
yep i made mine but dont work i dont know whats the problem
so i am gone get it from hidplanet
Old Apr 11, 2006
82801BA's Avatar
Can you post it and let me see how your wiring scheme is? There may be some problem during wiring...
Make sure you draw trigger power from COMMON from that photo otherwise it just won't power up(COMMON is the positive, and High/Low are the grounds)
Old Apr 11, 2006
jay78's Avatar
i dont have my camera on me today...
30 to the battery
86 ground
85 to the stock low beam wire
87 to the ballast..(split to two ballast)
i even swap the 86 and 87 still didnt work
on the h4 bulb it looks like this 3 pins ! - ! common low high
so black wire with tyc connector is common is ground wire ???
if thats wrong than i need to connect
85 to the stock common wich is in black wire
i am gone try this might work i think i was doing wrong way
after 15 mint
i tryd this way i can hear my relay making click noice when i turn the lights on but it dont turn my lights on.....so wats wrong now ?
Old Apr 11, 2006
2k2_civic_ex_4d's Avatar
2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold2k2_civic_ex_4d is a splendid one to behold
FYI for anyone who'd like a harness made for them I can take care of that.
Old Apr 11, 2006
jay78's Avatar
2k2_civic_ex_4d
thankx for helping me on aim
Old Apr 11, 2006
82801BA's Avatar
I do believe that you are connecting to the wrong wire....COMMON is POSITIVE, the stock LOW BEAM wire is NEGATIVE....
TYC has the wires reversed, which makes sense because it uses DC bulb(either way the bulb will turn ON, but it doesn't work for HID ballast and may risk damaging the ballast because you are sending positive DC to the ground through the ballast shell)....So all the BLACK wires on TYC are HOT, while the red and blue are GROUNDS....Trace the black wire you will find the HOT wire from stock H4 connector....
Old Apr 12, 2006
jay78's Avatar
their is two black wire i did found the right one and my relay making click noise but no light i also
try to connect this common wire straight to the battery and nothing happened to lights beside click
seince i was get click noice i knew that it has to be the 87 or 30 it was clicking but 30 wasnt throwing power to the 87....so i chked 87 and 30 found that 30 didnt had fuse in their and made me lol at my self
cuz i hve 5 fuse hanging by the bettery.....so i probly looked at the wrong one
its working perfect now....
thankx for the help guyz.
Old Apr 12, 2006
82801BA's Avatar
Nice that you finally figured out
Old Apr 13, 2006
jay78's Avatar
thankx for the help
rep4u
Old Apr 14, 2006
82801BA's Avatar
Hey, did you buy a relay socket? I can't find it anywhere in auto shop....Or you just connect the wires to the relay itself?
Old Apr 15, 2006
jay78's Avatar
u can do that too
i had relay leftover from my old alaram system and it alrady had socket.
u can probly find on ebay
this is how my relay looks like
jammer48
Oct 4, 2018 10:04 PM
h4ldol
Apr 24, 2017 08:16 PM
Deebo12
Air Conditioning
Sep 26, 2015 11:08 PM
pilebuck13
Sep 21, 2015 10:45 PM
Juanb24
Sep 15, 2015 12:39 AM
