Halo Projector Headlights
Old Mar 20, 2006
Thrasher086's Avatar
Thrasher086 is an unknown quantity at this point
I want to get a new look for my headlights without clearing or tinting them. Any one have these? They have 3 places the bulbs can go.
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
What is the difference with these cause I see four places the bulbs can go? http://cgi.ebay.com/ebaymotors/01-03...49213606QQrdZ1
If it is using the stock bulbs and harness then how can there be four places for the bulbs?
Old Mar 21, 2006
dirtySAMURAI's Avatar
I log in from time to time
they're different headlights. they use different bulbs than stock, but should come with a proper adapter to use with your stock wiring harness.
the main difference between those two headlights is that one of them has only a turn signal reflector whereas the other has turn signal and parking light reflector. you don't really need the parking light, but it's good to just plug it in to something. it's your choice which headlight to choose.
Old Mar 21, 2006
the one that looks like it had only one reflector actually still uses two parking lights. they just go in the same hole (one in middle and one to the left).
the light output is horrible. my friend had those and could barely see at night.
Old Mar 21, 2006
or that. i never owned either of those lights, so anyone else's (uneducated) guess is as good as mine.
i can imagine the light output being horrible.
Old Mar 21, 2006
see, two holes
Old Mar 21, 2006
RHCP0801's Avatar
ive heard of the light output being horrible also
Old Mar 21, 2006
see, two holes
i see it now
Old Mar 28, 2006
4rns860's Avatar
4rns860 is an unknown quantity at this point
headlamp
I have that exact same head lamp for my civic and the main headlight is halogen and the high beams came with the lamp the parking and turning lights are the only light I kept. and the halo's has wires for it and the socket is integrated with the high and low beam so there is really not much problem for me installing it and yes it does work. Well I am having trouble getting the halo lights to work (didn't know where to hook them up to)
Old Mar 28, 2006
scrimp's Avatar
scrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of lightscrimp is a glorious beacon of light
How was the light output on those? pretty crappy like everyone says?
Old Mar 28, 2006
either tap the parking lights or wire them to a switch directly to the battery. and yea any ground pics of the lights?
Old Mar 29, 2006
4rns860's Avatar
I'm pretty much satisfied with the light output of it and it is pretty bright, I'm no light science geek so I cannot tell you what kelvin measurements it has but I do know this you can replace the halogen bulb if you want to it's not really all that secure into the lamp.
and sorry i can't post any pics on this site
Old Mar 29, 2006
scrimp's Avatar
The thing is...i dont feel like spending the money for projectors with halogen bulbs and find out that I cannot see anything at night. Cant afford having a deer run in front of me and hit it coz of my headlights
Old Mar 29, 2006
my tyc projectors are very bright. it just has a different beam pattern like a W shape instead of big blob. Actually in those areas it has more light on the ground and also alot more side and bottom light (like having fog lights turned on).
Old Mar 29, 2006
scrimp's Avatar
Do u have HIDs in your TYC projectors gearbox or just regular halogens?
Old Mar 29, 2006
just halogen, osram silverstar clear bulbs.
Old Mar 29, 2006
rjngo's Avatar
rjngo will become famous soon enoughrjngo will become famous soon enough
stay stock...unless you'll do a retro on them plus with HID will be sweet
a pic i took one night i was bored:
Old Mar 30, 2006
scrimp's Avatar
Is that stock headlight housing with an HID kit or is that ebay projectors with halogens?
Old Mar 30, 2006
looks like projector with hid, not a retrofit.
Old Mar 30, 2006
Yeah I am a bit worried since I don't want to not see anything at night and if the stock headlights are brighter then that defeats the purpose.. I want a new look for the headlights so anyone have any other suggestions?
Old Mar 30, 2006
rjngo's Avatar
my headlight is stock...when i get enough money then i'll do a retro but for now, this is fine
Old Mar 30, 2006
i am working on something...but the halogen tyc with osram silverstar clear bulb is very bright to me. It is whiter and outshines most stock halogen on the road so i'm pretty happy. the only other way is get some nice fogs, with yellow bulbs to see better, which is what I'm working on. secret project for now.
Old Mar 30, 2006
hexed's Avatar
The black russian
hexed is an unknown quantity at this point
Will that setup with different bulbs work on these lights too? To make them brighter...?
Old Mar 30, 2006
i'm not sure how those compare, but imo tyc has the best lens. It has to its DOT approved. the rest are just cheap ebay junk.
Old Mar 30, 2006
Rufus's Avatar
They looked good after I put a ton of work into em including Audi S4 HID's. Olytrojan has them now, not in his car. PM him and he might sell em
Old Mar 30, 2006
scrimp's Avatar
That looks pretty sweet
Old Mar 30, 2006
VTEK2k2's Avatar
slave to the freaky ass booty
VTEK2k2 is an unknown quantity at this point
i have those headlights. the first ones with 3 holes. i think the light output is great. i never have any problems seeing things. im actually buying the other pair from someone on the site cause i want the dual halo's. if ur interested in them, i'll sell u them for cheap.
Old Mar 31, 2006
scrimp's Avatar
The ones ur selling look like these?
Old Mar 31, 2006
Rufus's Avatar
Those ARE the same ones and no I'm not selling them. Member Olytrojan has them. PM him. They are not on his car. You'd need Ballasts and D2R or D2S bulbs. I did the retrofit and had the insides painted NBP.
Old Apr 3, 2006
notoriouspyro's Avatar
Crack kills... But then again... So do I...
notoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the roughnotoriouspyro is a jewel in the rough
I hated them... I had them for almost a year and it wasn't a major problem because I had fogs as well, but when I put on the body kit, I lost my fogs and couldn't see jack. I was driving around with my hi-beams just to see the road, and that was with Silvanian Silverstars in both the projectors and hi-beams(almost $55 for two bulbs). 2 weekends ago I went back to my cleared stocks. Probably the best choice I could have made... Do yourself a favor and don't get them... While they look decent on the car they suck major ***...
Sidenote. Your best bet to connect the halos would be to either splice them into the parking lights, or run a switch into your car to turn them off and on as you see fit.
wingsfan19
Oct 1, 2015 03:45 AM
rnaodm
Sep 21, 2015 12:42 PM
shaejb15
Sep 12, 2015 01:02 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
