sidemarkers.. on or signal only?
Old Mar 17, 2006
jamesandrew58's Avatar
Super Member
jamesandrew58 is an unknown quantity at this point
ok 7thgen'ers its all up to u now! i have a hard desicion to choose so the votes will be my final desicion
2 options
on - sidemarkers on whenever parking/headlights are on
signal only - sidemarkers light when signals are used
thanks guys,
Old Mar 17, 2006
05_ CivicJDM's Avatar
I have mine hooked up on whenever parking/headlights are on, plus they blink alternately JDM Style!
Old Mar 17, 2006
FALKEN's Avatar
Civicforums Junkie
signal only
Old Mar 17, 2006
CustomXSpunjah's Avatar
CustomXSpunjah is an unknown quantity at this point
if they are real side markers, they should light up when the parking lights are on, and then flash when the blinkers are on. if they dont do that, buy new ones
Old Mar 17, 2006
signal only is the best imo. there is a 3rd option for doing both, but they will flash alternately.
Old Mar 18, 2006
Super Member
how do i wire them for both
Old Mar 18, 2006
sidemarker has two wires. connect one to the green signal wire, and the other to red parking light wire (no ground).
Old Mar 23, 2006
05reverb's Avatar
05reverb is an unknown quantity at this point
so the green signal wire is ground when there is no signaling? Is the accesory wire behind HU (switched 12+) like that too (ground when no power), if so, i wouldn't have needed a relay for my flashing alarm led.
Old Mar 30, 2006
J187's Avatar
J187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of lightJ187 is a glorious beacon of light
Signal only is how I have mine.
Old Mar 30, 2006
yea it acts like a false ground. its a ground when signal is off and not when signal is used.
Old Mar 30, 2006
05reverb's Avatar
so is the accesory wire (ignition) behind the hu the same way (ground when off)? anybody ever checked?
Old Mar 30, 2006
no its a second remote power turn-on. The deck has a main power and ground to the battery, but it wont turn on the deck until the ignition is also juiced up. Its like an ON switch then once the deck is operating, it feeds off the main power and ground wires.
Old Mar 30, 2006
05reverb's Avatar
hehehehe, i know that, i know what the ignition wire does and what it is for. My question is, when the ignition is off, is that wire ground?
Old Mar 30, 2006
oh, um, i dont think so
Old Mar 30, 2006
05reverb's Avatar
it's cause, when i installed my flashing led to come on when car is off, and to turn off when car is on, i used a relay, but in the package instructions, it said that one of the ground wires had to be on the ignition wire. and if the ignition wire is ground when car is of, i wouldn't need a relay. i'll check it when i install my new HU in a week, just wanted to know if somebody knew for sure
Old Apr 3, 2006
05reverb's Avatar
ya, i checked the lighter outlet + wire, and it is ground when the car is off, so i'm thinking that the ignition wire in back of the hu is the same.
Crazygrlinak
Oct 8, 2015 05:06 PM
sesi
Oct 1, 2015 02:03 PM
meicalnissyen
Sep 25, 2015 12:12 AM
