Replacement HID Bulb Question
Old Jan 6, 2006
LuZi0n's Avatar
LuZi0n is an unknown quantity at this point
I have had the XenonDepot HID 4300k kit since September 04. Some doubted if the bulbs were truly Phillips, who knows, but they are still shining brightly.
Anyway, I need to ask the question incase one of them went out. Would any replacement bulb work, or would I have to have one from XenonDepot in order for it to fit in the harness correctly?
Old Jan 7, 2006
dirtySAMURAI's Avatar
I log in from time to time
if your bulbs use a p32d base, then yes, any OEM replacement bulb would work. if it has 2 wires coming out of the base of the bulb, then you have to find another bulb that has 2 wires coming out of it. this is the downfall of the HID kit. if and when you need new bulbs, they cost over half as much as the entire kit costs. whereas OEM replacement bulbs cost $75 for both bulbs.
so chances are that you're going to have to hope that xenondepot doesnt shut down.
bsmiley
Apr 27, 2015 01:27 PM
thesushiboy
Apr 12, 2015 02:54 AM
CoolMD
Dec 6, 2001 10:40 PM
SWEETRIDE
Nov 27, 2001 05:52 PM
