Where to get fog power relay?
Old Jan 5, 2006
dalaw's Avatar
Bone Stock!
Do you guys know where I can get the power relay for 01-03 ebay fog lights? My fog lights stopped working 2 months ago and I suspect that the power relay is defective. I went to Kragen and they said they don't have it. Its a 12V 30A power relay. Thanks.
Old Jan 5, 2006
civicvtec1ps's Avatar
Search and Learn
Moved to lighting.
Should get better responses from this section.
Old Jan 6, 2006
CraigW's Avatar
How many terminals ?? Any other #s available ?? Should be able to find a replacement easily. Try www.mcminone.com or maybe even just the auto parts store.
Old Jan 6, 2006
TuRtLE714's Avatar
TuRtLE714 will become famous soon enoughTuRtLE714 will become famous soon enough
they have them at autozone...look near the foglight area.
Old Jan 6, 2006
dalaw's Avatar
Bone Stock!
it has 4 terminals. It also has this number on it, 42-1781.
Maybe I ll go to autozone later today to see if they have it.
Old Jan 6, 2006
CraigW's Avatar
Should be, 2 for the coil leads and 2 for the Normally Open contacts. The coil leads will show continuity with a meter. The other 2 will show open/infinite. Should be simple to find replacement.
Old Jan 6, 2006
dalaw's Avatar
Bone Stock!
I went to autozone today, and they have the power relay. But then when i put the new one in the car, the fog lights still wont come on, so i got it refunded right away, $4.32. Do you guys know what else could be the problem? The bulbs are fine, the power relay is fine, and the switch indicator light still comes on. Maybe the switch is bad?
Old Jan 6, 2006
MajinB's Avatar
Drunken Master-7thgen Ninja
have you checked the bulbs? have you taken a ohmeter to each of the above mentioned? do that first.
Jonnie.
Jan 13, 2019 11:21 AM
JAMorganIII
23
Jul 4, 2015 11:52 AM
Jeffdp
Jun 18, 2015 06:18 PM
Lopes101
Jun 7, 2015 08:04 PM
NukeSilo
Nov 20, 2001 05:17 PM
