HIDs with Halogen projectors?
Old Dec 20, 2005
FLAVOR247's Avatar
FLAVOR247 is an unknown quantity at this point
Im new to this board, and have a question in regards to using an HID kit with aftermarket TYC halogen projectors, has anyone done this? If so, how was the outcome?
Now I know by using the halogen projector, the light output will not display the multicolor flicker, like OEm HID projectors but with HIDs the light output should be mucher greater then the halogen setup and using the halogen projector should be a better setup then the scattered lighting of using an HID system in a reflective housing.
Im in the procees of doing a retrofit in my maxima, and this got me thinking.My wife owns a 2k1 civic with the TYC projectors and I was considering throwing in some HIDs in her headlights and getting rid of the halogens.
So, Im assuming I would just need to purchase and H3 HID kit(is that what the TYC projectors use?) and just swap them out?
Old Dec 20, 2005
A03's Avatar
A03
A03 is an unknown quantity at this point
When I bought TYCs for my 2003, they used H1 bulbs. The projectors might have been okay if the had a clean lens, but my particular set had what looked like a coating on them that started to flake away. It's hard to describe, but imagine a mostly transparent paint.. then imagine it cracking, and flaking off like as if you tried to paint somthing when it's freezing cold outside.
In short, the lenses were garbage. With those projectors, I think the outout would not be all that great. Maybe you'll have better luck and get some clean lenses.
With good lenses, in H1 projectors you are likely to get better results than with a stock reflector retrofit. (assuming you have a properly rebased bulb). Although it should work, it won't be nearly as good as a OEM xenon projector implant (you already seem to know this).
Old Dec 20, 2005
FLAVOR247's Avatar
Thanks for the reply. I hadnt really thought about the halogen projectors lens surface.
I may have to look real good at them.
Old Dec 20, 2005
jay78's Avatar
jay78 is on a distinguished road
tyc use H1 bulb....but u hve to retrofit the bulbs....wont fit....just hve to make the opening bit bigger...
did u reseal your lights after u bought it ?
Old Dec 20, 2005
FLAVOR247's Avatar
So your saying an HID H1 bulb will not fit into the current H1 socket thats on the TYC's?
My wife sold her OEM headlights when I installed the TYC's.
Thats was over 4yrs ago.
Old Dec 20, 2005
jay78's Avatar
h1 hid bulb will fit by making hole bit bigger.....so u hve to shave the opening...to fit the hid bulb in....
Old Dec 23, 2005
mikenam's Avatar
mikenam is an unknown quantity at this point
^yup a friend had tyc for his 00 SI w/ tyc lights. he had to dremel a little to fit the h1 bulb. Its a bitch cuz dust from dremeling gets in the headlights.
Old Dec 24, 2005
jay78's Avatar
make sure when u doing this u hve to put the light up then do it so dust dont get in....thats wat i did with mine.....dust still might get in but not that bad..
Old Dec 29, 2005
kimchi29's Avatar
soooon to be psshh
kimchi29 is an unknown quantity at this point
to be honest with you, getting hids in my tycs is what started on my light craze. my retrofit is going to be done on friday, anyways, heres a few pics of how my tycs with hids looked like
i had a h1 6000k hid kit, it was some weird japanese brand. anyways
warm up
cutoff wasnt that bad for some reason the driver side projector had a better light output and cleaner cutoff
as you can see, weird *** ground pattern
UltraHDGames
Jun 8, 2016 05:16 PM
wingsfan19
Oct 1, 2015 03:45 AM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
MamaBear2015
Sep 4, 2015 09:04 PM
