h3 hid bulb would fit aftermarket fog lights?
i planing to get fog lights with h3 housing....then i want to put h3 hid bulbs is this possible ???
would they accept hid bulbs or not
dont hve to retrofit like tyc headlight and h1 hid blub
as long as the bulb will fit in the housing, just get a rebased HID kit. it should fit unless you have to modify the opening like the tyc's
no, it wont fit, because the fog lights are too small. Im using IPAA 520 on my toyota and it works fine, but I c ouldnt fit h3 rebased into my Hella fog projectors on civic.No way to do it, the housing is too small, you will need to trim your rebased bulb lil bit in order to fit it into housing and it is pain in the neck.
