Lost a wire.
Old Nov 2, 2005
SimonTek's Avatar
SimonTek is an unknown quantity at this point
Lost a wire.
Ok, I am installing the fog lights, it tells me to run the wires along the fender (inside it) pop the plastic gromet, put the wires in. Then After I tear the interior apart, (I 90% of the dash is apart) It tells me to find the harnass I put thru the hole. I have no idea where this wire went to. Used flashlights to double check, even put cat 5 in the hole, figured maybe then I could find it. nope. Where do the wires come out?
Old Nov 2, 2005
SimonTek's Avatar
Keep waiting for a response, then the its 3am part reminds me. lol
*its 11:30am. No one has a clue? wow.
Old Nov 2, 2005
MegaHurtz's Avatar
This is an appropriate question for this forum, but might get a better response in Lighting
Old Nov 2, 2005
dirtySAMURAI's Avatar
I log in from time to time
it should be near the very front of the firewall from inside the cabin in the passenger footwell. it's waaaaaaaay deep inside and you will hurt your hands if you try and reach into it (i tried it, but gave up. i used a coat hanger, instead.). just keep fishing around in the corner at the top of the passenger footwell, but go deep in.
Old Nov 2, 2005
SimonTek's Avatar
Actually, I used a different hole. The directions said to use the hole on the bottom. I decide the one where there are two holes worked better. Used Cat5e to check the hole first. Since I have the interior apart. I am thinking of running cat5e cables for future use. You can use cat5e for low voltage use. (Its saved my rear a few times) Deciding on a few spots where to put it, so If I need it, I won't have to tear everything apart again.
Old Nov 3, 2005
Xenin's Avatar
Superior Evolutionary Element Destined-factor
Xenin is an unknown quantity at this point
i actually got my hands in there to grab the wire and my hands arent small. i'm just good with my hands, which is why the women like me.
Old Nov 3, 2005
SimonTek's Avatar
lol. Actually, what i need now is the harness that hooks up to the honda oe switch. its gonna be fun getting it.
2002ExCivic
22
Sep 28, 2015 08:29 AM
260000milesgoal
Sep 25, 2015 07:41 PM
Yang559
Transmission
Sep 21, 2015 01:41 PM
Jrosa
Sep 14, 2015 08:24 PM
Bman2212
Sep 2, 2015 11:49 AM
