how do you adjust headlights left to right?
Old Oct 23, 2005
kimchi29's Avatar
soooon to be psshh
kimchi29 is an unknown quantity at this point
cant find it anywhere
Old Oct 23, 2005
IrockCivics's Avatar
yeah I would like to know that also my driver side headlight is aiming all the way to the right.
Old Oct 23, 2005
PennyKnotOff's Avatar
the stock headlights right?
Old Oct 23, 2005
yeah
Old Oct 23, 2005
kimchi29's Avatar
soooon to be psshh
i just heard that you cant adjust the stock coupe headlights, is that true?
Old Oct 24, 2005
RHCP0801's Avatar
yes, its true, u cant adjust the coupe headlights to the side, only up and down
Old Oct 24, 2005
its true, only sedans have left/right. there is a second gear covered with plastic but you can always take it off. coupe doesn't have it.
Old Oct 25, 2005
dirtySAMURAI's Avatar
I log in from time to time
coupe is castrated.
Old Oct 25, 2005
PunkingCivic's Avatar
I need TP for my bunghole
Here this will help" http://www.7thgencivic.com/forums/sh...adjustment+56k
Old Oct 26, 2005
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
aka
drivers side - take out the lil power steering reservoir and cram yer hand down in there and turn the screws till stuff looks right
passangers side - unmount the battey but dont disconnect it then cram yer hand in there and turn the screws till stuff looks right...
Old Oct 26, 2005
TemjinX2's Avatar
thats for the vertical adjustment, not the left and right
Old Oct 26, 2005
i'm telling you, the coupe doesn't have left/right. it has only up/down.
Old Oct 26, 2005
TemjinX2's Avatar
He's correct.
Old Nov 5, 2005
mre's Avatar
mre
mre is an unknown quantity at this point
I have a sedan and I know how to adjust my headlights up and down.... But I've gone threw a few sets of bulbs and now im on HID's.. and my passenger side light... is dimmer then the drivers side..
How do I correct that? They are both aimed at the same height.. it seems as if my passenger side bulb is not sitting correctly in the lense.. IE... It's not mounted as Deep or as Shallow as the Drivers side.... Anyone have an Idea on how to correct it?
Old Nov 5, 2005
get rid of the kit and get a retrofit.
you could try to make sure the bulb is seated properly. make sure that both bulbs are exactly the same length and check to see where the light is arcing in relation to each other.
Old Nov 5, 2005
mre's Avatar
mre
.. kit is fine.... It has to be the lense... cause EVERY single bulb I've put in there... Stock.. SilverStar... Krypton Showoffs.. Nokya's... HID's... the passanger side light was always dimmer then the drivers side...
Also I have switched the bulbs from Driver to passenger... and the Passenger is dimmer.. Some how the bulb is not sitting correctly in the lense.. no matter how I try to adjust it...
Old Nov 20, 2005
es2k2's Avatar
Proud to be a civic owner
how do i take the cap out to adjust left and right?
if i pry it through, the cap will just fall off to bottom of the frame?
Sep 26, 2023 06:44 PM
fred57
Aug 1, 2015 08:45 AM
vtec92
HIDs and Retrofitting
Jul 16, 2015 03:55 AM
