How to get lights under the front seats
I'm trying to find out how to put in lights under my front seats, both driver and passenger seats, where the foot wells are, and if possible, also right under the back seats. I'm not sure which kind of lights to get, i.e. LED's, neons, etc.... since i've heard both ups and downs about many. If someone could throw me some suggestions of what to use and how to install it, appreciate it. I've got a 01 civic LX.
depends on what you want. big glow neons, directed spots led, ambient dim EL, etc. Just wire em to the 12v socket plug positive and negative and they'll come on when the ignition is on. Or you can throw in a switch on the positive wire and control them that way.
You can get them just about anywhere. Ebay comes to mind as a cheap place to buy some.
Just about any other caraccessory store online should have neons, too. Search around yourself. Heck, you could type in "Neons.com" I bet and get stores. Google it.
And good luck
And good luck
Crack kills... But then again... So do I...
It's not that hard at all. In fact, if you wanted to you could just go out and buy the neons that plug into your cig lighter, cut off the plug, attach the positive line to an inline fuse using the exact same fuse that's in the plug, and as stated above, depending how you want yours to turn on, either to a constant power such as the cig or if you want it on only at night, connect it to the headlights, or like I did, I cut a hole in my center consol in the little pocket and mounted a switch there. Then just attach the ground line to any metal point on the chassis. It's not hard at all...
Boost is so good make you wanna slap ya mamma
Here are some pics of my car when i had blue neons and now with red led's (pics of neons and leds). So you can compair what they look like. I did the led's myself and it wasnt that hard to do but as you can tell with the leds they are more direct spots of light and you have to wire alot of them (I wired 26 in total). I installed the leds on a red switch which you can see in one of the pics.
The leds only cost me $30 total including buying a soldering iron and 20 and 22 gauge wire.
The neons cost like $40.
if you want more specific details on how i did the leds or neons just ask me.
I bought the leds from here
jimmyfloyd
May 20, 2015 07:06 PM
