aiming 2005 headlights ( retrofit )
Old Sep 2, 2005
AlpJLFan's Avatar
AlpJLFan is an unknown quantity at this point
ok folks ive been searching on how to aim the 05 civic headlights and all i found was a thread that said " pop the hood, on the body of the frame is a place to use a philliips screwdriver "
problem is i dont see it.
i need to aim my HID retro lower cause it is way to high right now... theres a bolt on the back of the headlight but theres no diagram to say what it does.....
i need to know how to aim these down, if this has been discussed before can you link me to the right direction?
sorry folks but i need some help
Old Sep 2, 2005
Boggie1688's Avatar
Diamond Member
Boggie1688 is an unknown quantity at this point
Well basically turn the bolt counter clock wise to lower your headlight, and clockwise to raise it.
Old Sep 2, 2005
AlpJLFan's Avatar
the one on the back of the headlight right?
Old Sep 2, 2005
dirtySAMURAI's Avatar
I log in from time to time
could someone please post a pic of the back of said headlights? everyone asks, but not everyone has a 05 with aftermarket headlights.
Old Sep 2, 2005
AlpJLFan's Avatar
i just installed my aftermarket projectors and put my bumper and all back on so i cant really get a picture of the back of those, i can you some pics of the 05 OEM headlights..... gimme 10-15 minutes
Old Sep 2, 2005
AlpJLFan's Avatar
in pics 5 and 6 theres that silver bolt ( 10mm ) you see in the middle on the very bottom.
the aftermarket ones have a phillips screw. the oem ones just have a bolt with no other screws, and the aftermarket ones just have a phillips screw where the OEM ( 10mm ) bolt is and no other screws/ bolts
Old Sep 2, 2005
AlpJLFan's Avatar
theres diagrams on the oem headlight that say " D - U " and "R - L" like in the first 3 pics, but what the hell are you supposed to turn...?????? i dont understand the concept of adjusting these......
Old Sep 2, 2005
i get it. you have a coupe, correct? i guess honda changed their minds on the coupes again and decided to give you guys l/r adjustment instead of u/d. anyways, onto the problem.
you have a black cap on one of the screws that adjusts the main beam. you will have a tough time getting it vertically set, though, from what i can tell.
in this pic you can see what i'm talking about. look up and to the left of the low beam bulb and you will notice the black circular object. it *should* be a cap that you can pull off, but don't hold me to that.
Old Sep 2, 2005
bkidnon's Avatar
bkidnon is an unknown quantity at this point
That silver screw is the one to use for aiming low beams and high beams (up/down) .Same thing on aftermarket headlights. I'm finished with my retro but I don't have my digital camera with me so can't take pics yet.
Old Sep 2, 2005
AlpJLFan's Avatar
i figured it out. its that silver bolt that aims up/down, i didnt really mess with the left right cause i dont need to with my HID retrofit.
but with the aftermarket headlights theres a phillips screw instead of the 10mm bolt. i aimed the HID retro temporarily so i dont blind people and to get through the weekend. i let a friend borrow my digi cam cause she was going on a trip to florida, i should have pics of the HID retro installed after labor day with preliminary cut off pics. i got to find a wall with level ground around my area to aim them properly.
jtcavey
Sep 30, 2015 02:18 PM
brash99
Sep 29, 2015 08:42 AM
lolhowell
Photography & Videography
Sep 11, 2015 05:09 PM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
