HID's
Old Jul 31, 2005
rutscivic's Avatar
rutscivic is an unknown quantity at this point
HID's
whats the best brand of HID's for the money??? i NEED HID's!
Old Jul 31, 2005
Blahman240's Avatar
Touch it... He won't bite, He'll just come at you pretty quick.
Blahman240 is on a distinguished road
vividlights.com
Old Jul 31, 2005
02civic_rida's Avatar
www.honda-tech.com then go to the market place and there is a company selling a set for like 280 and no one has had any problems... hope that helps... btw i have xtec's and i havnt had any probs yet.
Old Jul 31, 2005
dirtySAMURAI's Avatar
I log in from time to time
oem.
Old Jul 31, 2005
Ramones's Avatar
Ramones is an unknown quantity at this point
There is NO need to buy a "kit".
Get casper shields and you can install OEM D2S/D2R bulbs into the factory H4 headlight.
Old Jul 31, 2005
^^^ a very good way as well.
Old Jul 31, 2005
Da1lyDr1ver's Avatar
where would you get the casper sheilds?
Old Jul 31, 2005
omg YES! finally someone understands!!!!
Old Jul 31, 2005
DAQIUN's Avatar
DAQIUN has a little shameless behaviour in the past
Where Can U Get The Casper Shields From
Old Jul 31, 2005
White05EXSE's Avatar
White05EXSE is an unknown quantity at this point
wat about doin that on an 04-05 headlight?
another question: if i hid'd my foglights, would they be bright enough to work at night w/o headlights?
Old Jul 31, 2005
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
you might want to call and see if they are instock. they were on back order.
https://www.casperselectronics.com/M...Category_Code=
Old Jul 31, 2005
Ramones's Avatar
With the casper shields, i read the fitment is not 100% perfect. You will have to JB weld the base of the HID bulb to the shield itself.
Old Jul 31, 2005
D5cIvIc's Avatar
OEM are not Plug and Play through correct?
Old Jul 31, 2005
you can use a screw and cut the head off. that way the bulb doesn't move around.
Old Jul 31, 2005
Caucasian.Asian's Avatar
can you give more info on this capser shields and oem bulbs??? i don't know anything about HIDs.
thanks
Old Jul 31, 2005
caspers h4 adapter shield.
d2r bulbs are oem in reflector HID equipped vehicles.
Old Jul 31, 2005
FALKEN's Avatar
Civicforums Junkie
moved to the Lighting forum
Old Aug 1, 2005
Hefe's Avatar
Second Place is the First Loser
Hefe is a jewel in the roughHefe is a jewel in the roughHefe is a jewel in the rough
paint the casper shields black (with some high quality/temp paint).. or you will get a lot of yellow light!!
Old Aug 1, 2005
gh0st's Avatar
TAQUITOS!!!!
and please stay below 6000K. anything above that is just stupid
Old Aug 2, 2005
rutscivic's Avatar
ooook so nobody REALLY answered my original question
Old Aug 2, 2005
fine. you want a BRAND? philips. hands down the best.
!!!HOWEVER!!! do NOT get caught up in this "philips" binge only to get scammed by some punk on ebay selling "genuine philips 12000k hid kit" cause there is NO SUCH THING AS A PHILIPS 12000K KIT! there's only 2800k, 4100k, and 6000k (but the 6000k is only for color matching your used 4100k bulbs and are labelled "off-road use only").
Old Aug 2, 2005
rutscivic's Avatar
thank you!
Old Aug 2, 2005
so all you need to do is get the plug and play hid (like this http://cgi.ebay.com/ebaymotors/NEW-6...89827670QQrdZ1)
and the casper shields, and you will have virtually no glare????
or what?
Old Aug 2, 2005
no. plug and play is plug and play.
oem is not directly plug and play. here's a list of what you need for OEM setup:
Philips 85126 D2R bulbs, Philips 85122 D2S (normally used for projectors, but can be used in this application also) bulbs, or Osram D2R bulb
Caspers H4/D2 adapter shield
OEM Ballasts/ignitor - the "recommended" ballast would be the Hella gen 3
Wiring harness - you can make this yourself or get one from somewhere
Install all of it properly and you will have an almost perfect reflector beam pattern with NO HIGH BEAMS.
you could probably get all of the hid equipment from xenondepot.com
Old Aug 2, 2005
or what?
tsk tsk tsk on the ebay link. anything that is NOT d2s or d2r will be a fake. an asian made product that will go bye bye in about a month, or if you're lucky, 6 months.
look for authentic philips. if it doesn't say philips on the actual product, it isn't philips.
Old Aug 2, 2005
kickercivic1's Avatar
kickercivic1 is an unknown quantity at this point
so whats the difference between d2s or d2r?
Old Aug 2, 2005
wow, seems complicated. i shall consult with you if i ever decide to get hids.
Old Aug 2, 2005
d2s = projector use
d2r = reflector use
for example: those flashing blue/white lights you see on bmws, audis, newer maximas, s2000s, etc, are from a projector and a d2s bulb. the constant bright white/hint of blue or purple you see on older acura TLs, RLs, CLs, some mercedes, many nissans, etc, are from a reflector (like your civic) and a d2r bulb.
the way i remember it is:
D2R = reflector
D2S = not R...
Old Aug 2, 2005
ID:	57995   Click image for larger version
Old Aug 2, 2005
chrisleecool's Avatar
selling my xtec 5000k hid soon
let me know if you're interested
i'll let'em go for 240shipped
