HID's
Old Aug 3, 2005
  #31
82801BA's Avatar
82801BA is an unknown quantity at this point
I remember I once installed the casper kit.....m.....Coupe model doesn't really fit because of the size of the front cap inside the housing, it's just too small.....Sedan headlight, I tried, is better, but the spacing between the cap and the reflector is too great, I got hot at least 2 hot spots on each side of the light, where I can see the burning filament from an angle in front of the car......Too bad....
Old Aug 3, 2005
  #32
kickercivic1's Avatar
kickercivic1 is an unknown quantity at this point
really nice too now.
Old Aug 3, 2005
  #33
How many people here have use "casper kit"??
Old Aug 3, 2005
  #34
dirtySAMURAI's Avatar
I log in from time to time
probably only 1: 82801BA lol. well...it's not like many people know of the shields. they just think "oh, h4 means i need h4 kit."
Old Aug 3, 2005
  #35
civicfreak84's Avatar
civicfreak84 is an unknown quantity at this point
is xtex phillips
Old Aug 3, 2005
  #36
82801BA's Avatar
Yes, may be I am the only one...ha...I still have the shields with me that I put black hi-temp paint on it already....It made some yellowish white color from the reflector....But as I said, I don't like the 2 points on each side that I really can see the burning gas....Just too much glare when looking at it...
Old Aug 3, 2005
  #37
82801BA's Avatar
Another problem is that you really want the bulb's return line to be exactly vertical, so got to put the shield in first, then the bulb....
Old Aug 3, 2005
  #38
does xtex contain phillips bulbs?
and if I wanted to make my headlights into a projector for my kit how do I go about doing this?
Oh and in this link: http://cgi.ebay.com/ebaymotors/NEW-H...8601QQtcZphoto
what does it mean high and low? Are these phillips?
Old Aug 3, 2005
  #39
no xtex is not philips. philips is philips. on ebay, everything is philips, so don't get it from ebay cause they're all lying sacks of ****.
in the link that is NOT a philips product. philips comes ONLY IN D2S OR D2R. no other base.
Old Aug 3, 2005
  #40
82801BA's Avatar
Basically I fit OEM Osram Xenarc D2R (with grey shield, right?) into Casper....It turns out to be completely blue initially, then as it brightens, slowly turns yellow, and more yellow...
Old Aug 3, 2005
  #41
Are you telling us what happened or are you hypothetically guessing what would happen?
Old Aug 3, 2005
  #42
Originally Posted by soonercivic
you might want to call and see if they are instock. they were on back order.
https://www.casperselectronics.com/M...Category_Code=
anyone have a promotion code for this?
Old Aug 3, 2005
  #43
gh0st's Avatar
TAQUITOS!!!!
you can always make your own casper shield...bunch of different things people have used on hidplanet.com
Old Aug 3, 2005
  #44
turkey baster, for example...
Old Aug 3, 2005
  #45
Ramones's Avatar
Ramones is an unknown quantity at this point
I'd rather buy from casper...with a turkey baster you have to measure and buy a dremel to cut it.
Old Aug 5, 2005
  #46
AlpJLFan's Avatar
AlpJLFan is an unknown quantity at this point
man id like to see some cut off pics against the a wall with these casper shields
Old Sep 4, 2005
  #47
v8eaterokv6's Avatar
i have a new home do u
ballasts would any of these ballasts work or are they junk. its the only place i can really find ballasts for sale.
Old Sep 4, 2005
  #48
ebay works. just make sure you get the proper socket for the ballasts (p32-d - looks like a circle. it does not have 2 connectors for the bulb). or you could try www.hidplanet.com
Old Sep 4, 2005
  #49
TemjinX2's Avatar
i would get them from hidplanet on the forums, you can get them for cheaper on there.
Old Sep 5, 2005
  #50
82801BA's Avatar
I want to know if I am to retrofit projector into TYC, which projector has the best fit?
Old Sep 5, 2005
  #51
valeo
Old Sep 5, 2005
  #52
82801BA's Avatar
I've heard that Borsch fits better(smaller), and some said Valeo are better, why?
Old Sep 6, 2005
  #53
TemjinX2's Avatar
go to hidplanet...it'll prretty much answer all your questions. questions like this has been answered over there over and over again. From what i read valeos output the most light for its size. There are projectors that output more light, for example the s2000 projectors, but they would be difficult to install.
Old Sep 6, 2005
  #54
valeo will fit. trust me. i had both projectors at one time and i will tell you now that if you buy the bosch single xenon (or bi-xenon) you will not be able to fit it into the tyc headlights without major modification. valeos slide in.
Old Sep 6, 2005
  #55
ok this is my last question are these true hella gen 3 ballasts does this look right i have never bought anything off ebay before
Old Sep 6, 2005
  #56
what?
Old Sep 6, 2005
  #57
TemjinX2's Avatar
i link to the ebay auction would help.
Old Sep 6, 2005
  #58
ballasts sorry i was in a hurry to get to class and forgot the link here it is
Old Sep 6, 2005
  #59
those are good. the seller is xenondepot - www.xenondepot.com
Old Sep 6, 2005
  #60
thanks infinite + rep
UltraHDGames
Jun 8, 2016 05:16 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
MamaBear2015
Sep 4, 2015 09:04 PM
Voiceofid
Feb 3, 2002 03:54 PM
