my lights fogged up
my lights fogged up
wats up guys...my freaking headlights fogged up a couple days ago from a heavy rain...im gonna reseal them...anyone know a good one to do it with..cause i dont wanna get a cheap one...i need a good one that wont let it fog up again
4 cyllinders are good but 5 is better!
use either bathroom caulking or silicone sealant. Either one can be found at your local hardware store. Both work great both do the same thing but i think that caulking is a little bit less crumbly. Silicone crumbles really easily once it dries. Caulking is more like rubber. IMO get some CLEAR caulking fill in the grooves where the two pieces come together. Dont be stingy. Once you have the cuaking in the grooves push the two pieces together and wipe off the excess caulking that oozes through the crack and whala that's it. Give it a couple of days to completely dry. i did this method and no fog whatsoever. As extra precaution, once the caulking is dry, you can also put some more caulking on your finger and rub it into the crack all the way around the lamp. It will dry clear so you wont see it plus it's gonna be under your hood and bumper anyways. Good Luck.
