your thoughts on this kit
Old Jun 3, 2005
jttegx's Avatar
OMNES AD UNUM
http://www.hid-vision.com/catalog/
im still doing research on hid kits for h4, and i came upon this one. let me know your thoughts and opinions
Old Jun 4, 2005
dirtySAMURAI's Avatar
I log in from time to time
dont get a kit for H4. get D2S bulbs with a caspers electronics H4-D2S adapter shield. stick with OEM...
D2S bulbs = $75 for a pair at www.hidplanet.com
caspers electronics shield = ~$30 on ebay?
ballasts = ~$170 on the for sale/trade forums at www.hidplanet.com/forums
wiring harness = ~$30 DIY or ~$50 if you buy from someone/somewhere
it may be more expensive, but it is well worth it to stick to OEM and not get a kit that will burn out too soon and then you are stuck trying to find kit specific bulbs for the rest of your life...
Old Jun 4, 2005
https://www.casperselectronics.com/M...&Category_Code
for the casper shield. i couldnt find it on ebay, so here's a direct link to caspers website.
Old Jun 5, 2005
Remigijus's Avatar
Remigijus is an unknown quantity at this point
Is it needed to make any modifications to the headlight?
Does it necessarily have to be a projector in it?
Is it possible to convert to HID with the original OEM headlight?
Old Jun 5, 2005
i posted that information above. no modification needed. just buy the stuff that i listed and you're set (if you have a 01-03 civic)
Old Jun 5, 2005
jttegx's Avatar
OMNES AD UNUM
hmm, im not familar with ballasts, ds2, shields, etc. i was hoping i could find a simple plug and play hid kit for h4 that will work great for OEM housing under $300-+.
Old Jun 5, 2005
johnbt23's Avatar
i was wondering for 04-05 civics, would you have to use totally different hid bulbs and ballasts for the headlights?
Old Jun 5, 2005
Remigijus's Avatar
If this is the case, than why are projectors needed?
I've read that some forum members took their headlights apart and installed the projectors.
So why are they needed if HID bulbs can do what they should do without projectors? What is the atvantage of having them installed?
Old Jun 5, 2005
XSRCivic's Avatar
XSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really niceXSRCivic is just really nice
they install the projectors to reduce glare from the HID. There will be more glare from a headlamp with reflectors in it (like ours) then there will be with the projectors installed.
Old Jun 5, 2005
Remigijus: as was stated by XSRCivic, projectors are used so that the lights have minimal to no glare at all. Glare is defined as any unwanted or stray light that shines into oncomming traffic's eyes. Glare is bad. If you install a generic ebay HID kit, then you will have massive glare and blind the living daylight (or nightlight) out of the people in front of you.
johnbt23: Totally different HID bulbs and ballasts? Not necessarily. If you stick to D2S and some sort of adapter for 9006, then I'm sure you could use OE HID.
sch2cm
Jul 21, 2015 09:58 PM
cizsak
Jul 21, 2015 03:39 PM
liagreenhalgh92
Jul 21, 2015 01:31 PM
chrisjackson321
Jul 12, 2015 03:00 PM
beeemerdude
Jul 10, 2015 09:22 PM
