resmoke tails?
Old May 22, 2005
grenloch101056's Avatar
grenloch101056 is an unknown quantity at this point
Question resmoke tails?
so i bought these tails from a member on this board, and one of the tails is starting to look pretty junky
I think the clear and the tint is starting to come off, whats the best way to repair? Could i sand it down and just start it all over, or would that screw up the finish when I respray it? Heres a closeup of the damage.
on my other tail, the clear is startin to chip off. Can i just clean it well and respray it with clear?
thanks for everyone's help
Old May 22, 2005
PennyKnotOff's Avatar
Only way is to sand and respray. Make sure you use atleast 800+ (correct me if i'm wrong) grit wet dry sand paper. Try not to get any deep scratches or pitting. Good luck
Edit: Forgot to say once you sand it's not gonna look nearly as clear as it does now so just keep that in mind.
Old May 23, 2005
thats what i was figuring, so the best way is to just get a new set of tails and tint them? what about sanding and then working my way up to a polishing compound, will the light still be destorted?
Old May 24, 2005
When you sand them the light won't be distored but you won't be able to look into the tails cause the clear covers will have a foggy look. Just smoke them so they look black but not too dark and you should be fine.
Old May 27, 2005
ragingSPAM's Avatar
I just burnt my tongue
actually for the respraying of clear coat he should scuff up the taillight clear thats already on so its not shiny with a gray scotch bright pad or 600 grit wet sand paper...than if he's using real clearcoat in a spray gun than it'll come out real nice
Old May 27, 2005
so lemme get this straight, if i sand down to the clear plastic, then respray the tint and clear them using clearcoat from a spray can, it shouldnt look too bad?
Old May 27, 2005
Depends on the type of tint your using. Some tint doesn't take clearcoat well and ends up looking like crap. The one I used already has a gloss finish to it and your not supposed to use clear coat. I found out the hard way......
Old May 30, 2005
soonercivic's Avatar
soonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the roughsoonercivic is a jewel in the rough
i dont know if it would work or not, but you might try some clear plastic polish. I know it works great for clear plastic but dont know how it would do for this. just an idea.
Sep 27, 2015 11:33 AM
Klame9420
Sep 18, 2015 12:37 PM
spyder13
Jul 31, 2015 06:31 PM
h4ldol
19
Jul 28, 2015 01:01 AM
