passanger side high/low beam not working
Old Apr 18, 2005
Civic_RedLine's Avatar
im stock now! T.T
Civic_RedLine will become famous soon enough
ok, I am going to the dealer tomorrow to figure out whats wrong with my headlights. First I had projectors and the passanger side bulb went out, so I changed the bulbs and still no light from only the passanger side. I change my lights back to oem and still no light. All bulbs were good. So its probably my wires or a fuse?
can anyone point me to the right direction so that I dont waste more money at the dealership?
Old Apr 18, 2005
Nameless's Avatar
TURTLEonK
Nameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the roughNameless is a jewel in the rough
You might've melted your wiring harness?
Old Apr 18, 2005
CraigW's Avatar
There is 1 fuse per headlight, 15 amp in the under hood box have you checked there ?
And yes, you may have damaged the sockets or wiring.
Old Apr 18, 2005
im stock now! T.T
no it was to odark, im going to check the fuses, i checked the wires, nothing is wrong with the wires cuz i never even did anything to them except splice the halo ring onto the stock wire but that s about it. ill check the fuse. do you know which one it is?
Old Apr 18, 2005
CraigW's Avatar
The wiring info I have states the "underhood box" the info will be on the lid as which fuse is which.
Old Apr 18, 2005
im stock now! T.T
yeah it was the fusebox, shouldve checked it first before checking anything else. Oh well, thanks though.
Old Apr 18, 2005
noVICe's Avatar
noVICe is an unknown quantity at this point
encountered the same problem as i did when i had my projectors for the accord. i went through new sets of bulbs every 3 months. i figured it out after like a week of examination and it appears that the clip that holds the bulb in the socket has this little metal piece that acts as a relay or something. just make sure the screw that holds the wire in is snug. it should help.
Old Apr 18, 2005
noVICe's Avatar
^^^dont quote me... im not sure what i just said.
Old Apr 18, 2005
im stock now! T.T
the projector bulbs actually never died out on me. It was the fuse. I gave the projectors away for a pair of silverstars.
numbersguy
Electrical DIY
Sep 15, 2018 11:24 PM
intensity
May 12, 2015 10:43 PM
got2kids
May 9, 2015 06:45 PM
ORskier
May 3, 2015 12:54 PM
