Bolt size anyone ?
Old Apr 7, 2005
FaiJai's Avatar
FaiJai is an unknown quantity at this point
Bolt size anyone ?
Stripped the bolt that holds the headlights underneath. does anybody know what the size of the bolt is? thanks
Old Apr 7, 2005
ImPulse's Avatar
all the bolts that are on the headlight are 10mm... so just find a 10mm bolt
Old Apr 7, 2005
ImPulse's Avatar
1) on the top above headlight
2) the screw.. which is also 10mm
3) on the side/bracket/frame 10mm
4) underneath the headlight (holding the BRACKET onto the headlight)
5) you need an extension, and that connects the bracket to the frame
all 10mm
Old Apr 7, 2005
FaiJai's Avatar
thanks man !
Old Apr 7, 2005
FaiJai's Avatar
wait but 10mm is for the hex. not the thread size or is it the same ?
Old Apr 7, 2005
teampointless's Avatar
Ultimate Member
http://www.hondaautomotiveparts.com/...gry5=HEADLIGHT
#11 on there.
Old Apr 7, 2005
ImPulse's Avatar
when i lost some bolts i just used a regular 10mm screw
Strycker
Aug 18, 2015 02:25 PM
Theshwartz35
Jul 17, 2015 11:13 PM
