HELP! Connecting Halo wiring......
Old Apr 1, 2005
04RedCiVP's Avatar
Every predator is someone elses prey!
04RedCiVP is an unknown quantity at this point
Okay, Im well aware its a friday night and probably NO ONE will read this or respond...but I need some help. I am hooking up my angel eye headlights and Im not sure how to connect the wire(s) coming from the halo to the car wiring....make sense? There is a black and a red wire coming from the headlight...how and where do I connect this to...obviously I dont have to connect the halo up but I wanna get this done tonight...any help is appreciated!
Old Apr 1, 2005
Well let's see. The basics are red = power and black = ground. Now keeping this in mind, you hook the red wire to a power source depending on when you want them on. The ground just goes to the chassis where there's bare metal. A good spot is the stock ground above the radiator where the engine cable grounds to. For power, you can connect it to different places. If you want them to turn on with the parking lights, pull out the plastic fender and reach in for the small bulb in the middle. Tap the red wire from the halos to the red wire going to the little parking light bulb. That's it. You can also tap the red halo wire directly to the battery and put a switch inbetween to control when power gets to the halos. So you would have power wire from the battery to the input terminal on the switch and continue the wire off the output terminal of the switch and then to the halos, then connect the ground. Easy as pie.
Old Apr 2, 2005
04RedCiVP's Avatar
Thanks for the help. Before reading your post I was anxious and went about installation by 'winging it.' All I did was splice the red wire into the parking light red wire and the black to the black...I checked everything after installation and everything seemed to work fine. I left the lights on for about a minute or two and didnt experience any explosions, fires, or natural disasters...hopefully it'll stay that way. Let me know if I should expect any problems to occur with installing it this way.....I cant wait to take pics of em...they're bad-azzz!
Old Apr 2, 2005
04vic's Avatar
04vic is an unknown quantity at this point
Originally Posted by 04RedCiVP
they're bad-azzz!
pics and price....
Old Apr 2, 2005
no you installed em correctly. The only problem you may have is the cheap leds burning out quickly, that's why most people open em up and put more/better leds behind the ring. But you don't have to for now.
Old Apr 2, 2005
04RedCiVP's Avatar
Originally Posted by 04vic
pics and price....
I'll take pics of 'em tonight....I'd take a day pic but that'd be just a tease, I think.
Whew...good to hear they are wired correctly. Damn, so the LEDs are cheap are they, bummer! Now when you say people open em up and put better leds behind the ring, do you actually mean open up the entire headlight (as if you were to paint your housing) or do you mean just install different bulb...sorry for the confusion and excuse my ignorance...thanks in advance!
Old Apr 2, 2005
dirtySAMURAI's Avatar
I log in from time to time
open them up as if you were painting the housings
Old Apr 2, 2005
04RedCiVP's Avatar
thanks.
Old Apr 2, 2005
Akutenshi's Avatar
The Rizing Sun
u got those new 04-05 angel eye projectors? or made ur own angeleyes for the stock 04-05 housing?
Old Apr 2, 2005
hondaes1's Avatar
hondaes1 has disabled reputation
These are the ones he got.
http://cgi.ebay.com/ebaymotors/ws/eB...OAB%3AUS%3A201
Old Apr 2, 2005
yay. sucky output
Old Apr 2, 2005
Akutenshi's Avatar
The Rizing Sun
yeah those are the ones i was thinking of. i didnt kno he bought em tho :P damnu!
Old Apr 2, 2005
04RedCiVP's Avatar
yay. sucky output
actually light output isnt sucky, IMO. I'll take pics tonite and show y'all.....Im sure everyone and their brother will begin buying these projectors now that they've been released for the 04-05's....at least Im one of the first (puts head down in shame and cries.. )
Old Apr 2, 2005
Akutenshi's Avatar
The Rizing Sun
the auctions on ebay said that theyre NOT HID compatible... does that mean even if u have a HID kit for the H4's and H1s. u cant use it on these projectors.....even tho those are the bulbs they use?
btw.... take lots of pics so we can see how they look
Old Apr 2, 2005
04RedCiVP's Avatar
go here for the pics:
http://www.7thgencivic.com/forums/sh...17#post2913017
ricer_em2
May 11, 2016 08:09 PM
haloway13
Nov 6, 2015 10:43 AM
wingsfan19
Oct 1, 2015 03:45 AM
Bruce2
Sep 27, 2015 08:45 PM
IronFist
Sep 25, 2015 07:13 PM
