projection headlights
Old Mar 27, 2005
DAQIUN's Avatar
DAQIUN has a little shameless behaviour in the past
Lightbulb projection headlights
I don't know if this a repost. but i got know.
I thought that they weren't not going to make projector headlights for the 04 05 headlights.
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Old Mar 27, 2005
Akutenshi's Avatar
The Rizing Sun
TYCisnt going to be making projector headlights for the 04-05s....... but those arent made by TYC....... and yes. this is like the 5th thread on the new projector headlights
Old Mar 27, 2005
AzNmiKex215's Avatar
2k1civic.com O. G.
id get them only if i was doing a retrofit for them.
Old Mar 27, 2005
DAQIUN's Avatar
what is the problem.... tyc makes the better brand of the projection headlights...
Old Mar 27, 2005
FALKEN's Avatar
Civicforums Junkie
moved to the Lighting forum
Old Mar 27, 2005
wonderz's Avatar
wonderz is on a distinguished road
man, i wonder how many times falken does ^that^ every week.
Old Mar 28, 2005
xxhonda4lifexx's Avatar
xxhonda4lifexx has a little shameless behaviour in the past
I wonder if they make projectors that would be able to accomodate HIDs for our Civics? I know that our stock halogen runs on H4. I just converted to HID and the H4 HID bulb is slightly longer than halogen - this won't fit in most projectors. Any of you guys know which type of projectors have a deep enough space for HID??
Old Mar 28, 2005
dirtySAMURAI's Avatar
I log in from time to time
what the funk? read up on HIDs at hidplanet.com/forums
but basically, if you want to put a HID KIT into your car, then the manufacturer of the KIT will have the arc of the HID capsule be as close to where the halogen filament sits in relation to the halogen bulb. H4 bulbs will NOT fit into a projector headlight. most of the aftermarket headlights are H1 bulbs and these are very small bulbs. buy a kit and you should be fine (for the short term). do a retrofit and you'll be set.
Old Mar 28, 2005
wonderz's Avatar
actually i think most aftermarket headlight uses h3 bulbs for low beam and h1 for high beam. but either way, they are very small bulbs that fit into projector housing.
Old Mar 28, 2005
tyc uses H1 for both low and high beam, and i've only owned 3 pairs of tycs...lol
Old Mar 28, 2005
wonderz's Avatar
yea, but that's just tyc.. if u check other projectors like ones for RSX or halo projectors, they use h3.
Old Mar 30, 2005
DAQIUN's Avatar
so basically ya'll saying that if i was to buy those projection headlights off of ebay i would not be able to fit the HIDs in. or would i.. I'm really what to get the projection headlight, but only if i can put the HIDs in without retrofitting.
Old Mar 30, 2005
Amer786's Avatar
Senior Member
Amer786 is an unknown quantity at this point
From what I understand , you can put HID in the TYCs as long as they are H1. But these will not be as bright as uding H4 HIDs in the stock housing...am I right guys? One question on the TYCs, is the third socket for the turn signal bulb?
Old Mar 30, 2005
TYCs have 4 sockets. 2x H1, 1x parking light, 1x turn signal.
TYCs can hold a H1 HID capsule, but the light output will be comparable to maybe a flashlight on crack. Retrofit or bust.
H4 with HID will be bright (only because it's a very large reflector). if you do a retrofit, you will have better light than just with a kit.
Old Mar 31, 2005
Amer786's Avatar
Senior Member
So what if one went with a TYC assembly and H1 Halogens Impulse is selling, will that work from brightness point of view?
Old Mar 31, 2005
2K2SilverCivicSiR's Avatar
2K2SilverCivicSiR is an unknown quantity at this point
how much work is need for retrofitting..
and what are needed...
Old Mar 31, 2005
gh0st's Avatar
TAQUITOS!!!!
depends on your technical skill...cutting, sanding, etc
you need quite a bit of stuff, projectors, ballast, ignitors, bulbs, extra stuff necessary to make them all fit...
www.hidplanet.com/forums is a great place to start. read before you hack up anything
Old Mar 31, 2005
thekuai's Avatar
thekuai will become famous soon enoughthekuai will become famous soon enough
the correct answer is searching is needed...OR LOOK AT THE DAMM STICKIES ON TOP OF THIS FORUM!!!
http://www.7thgencivic.com/forums/sh...d.php?t=194211
Old Mar 31, 2005
^wow. ouch. getting all up on the OGs back.
it'll still not be as bright as a HID retrofit. halogen inside the craptacular TYC projectors will still be halogens inside a craptacular projector.
Old Apr 3, 2005
beewhyon's Avatar
beewhyon is an unknown quantity at this point
actually you can fit HID kit bulbs into those aftermarket projectors, I just bought those new 2004 projector headlights and it fitted...well I made it fit...all you have to do is get a dremel tool, and grind the base a little bit to make it fit and viola, heres a picture of mine with HID's
Old Apr 3, 2005
got any wall shots?
Old Apr 3, 2005
Akutenshi's Avatar
The Rizing Sun
so ur using a 9006 hid kit ?
Old Apr 4, 2005
thekuai's Avatar
i believe the projectors use h1
Mad Dog Tannen
Oct 19, 2016 08:12 PM
ricer_em2
May 11, 2016 08:09 PM
wingsfan19
Oct 1, 2015 03:45 AM
Bricoleur
Sep 9, 2015 12:23 PM
MamaBear2015
Sep 4, 2015 09:04 PM
