the EASY way to install 6x9 speakers
Old Mar 8, 2005
thekuai's Avatar
thekuai will become famous soon enoughthekuai will become famous soon enough
This originally came to me when i had my 94 pontiac grand am gt coupe that also had 6x9 in the rear deck. The setup was the same as the civic, the screws holding the speakers in were facing down and were visible. So how did i remove it so easily?
1)Take a drill (cordless recommended) and take off the philips head attachment or drill bit whatever you have in there.
2)Open up the chuck (open the mouth that grips onto bits/philip bits) and place the wide hole on the bottom of the screw.
3)Now tighten the chuch (the hold that grips the bit) until its nice and snug with the bottom of the screw.
4)Now put the drill in foward or was it reverse? (clockwise) and squeeze the trigger slowly....the screw should reverse vertically! Repeat for all four screws and your speaker should come out!
now when your done with placing the new speakers into place just turn the screws upside down the end is facing up so it is easier to install/remove next time!
Enjoy! Let me know if this works for you!
Old Mar 8, 2005
thekuai's Avatar
whoops please move this to the ice section heheheh
Old Mar 8, 2005
PopcornPlaya's Avatar
Electric Boogaloo...
So yoou're saying to cross thread them and leave the old ones in the rear deck so you don't have to remove it? Wow, that won't rattle (10).
Old Mar 8, 2005
thekuai's Avatar
leave the old ones? when you pop out the old speakers from underneath you can remove the screws....
"now when your done with placing the new speakers into place just turn the screws upside down the end is facing up so it is easier to install/remove next time!"
Old Mar 8, 2005
tbaleno's Avatar
tbaleno is an unknown quantity at this point
good tip
Old Mar 8, 2005
PunkingCivic's Avatar
I need TP for my bunghole
clever
I wounder if that will work on the civic though
plus with aftermarket speakers you might have to do the truck shock DIY due to the speaker magnet and the trunk spring hitting each other.
Old Mar 8, 2005
MegaHurtz's Avatar
wont work on the vics
speakers go in from the top
Misfit2613
Jul 30, 2015 09:49 AM
NoobyKid
Jul 13, 2015 07:53 AM
Bill in San Jos
Jul 10, 2015 12:32 PM
fvckbg
Jul 7, 2015 07:08 PM
robbie374
Jul 7, 2015 02:56 AM
