HIDs w/projectors
Old Feb 22, 2005
binky's Avatar
binky is an unknown quantity at this point
HIDs w/projectors
will an HID kit work with TYC projectors and does anyone know if the light output will be worse with them? Also, what make of HID kit does everyone prefer? thanxs for the help.
Old Feb 22, 2005
kimchi29's Avatar
soooon to be psshh
kimchi29 is an unknown quantity at this point
i used to have hids in my tycs. light output is decent. not great not bad. get the hid kit from impulse. make sure you get h1 though. check out my userpics for pics
Old Feb 22, 2005
ImPulse's Avatar
An HID kit in TYCs will be fine but, you will have to enlarge the bulb opening in the back to allow the hid bulb to fit. The light output will be fine since you are using TYCs.
btw, I sell HID Kits,
http://www.7thgencivic.com/forums/sh...d.php?t=194208
wrong forum to
Old Feb 22, 2005
FALKEN's Avatar
Civicforums Junkie
moved to the Lighting forum
Old Mar 3, 2005
Dark_Pyro7's Avatar
Dark_Pyro7 is an unknown quantity at this point
I am planning on buying the 5000k Xtec kit from Impulse. But how much modification is required to get them to fit in to TYCs? How do you enlarge the opening? I was under the influence it was plug and play...
Old Mar 3, 2005
dirtySAMURAI's Avatar
I log in from time to time
it is plug and play after you hack away some of the bulb holder on the tyc projectors.
Old Mar 11, 2005
HondaSales's Avatar
HondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of lightHondaSales is a glorious beacon of light
it wasn't hard at all and light output is decent
Old Mar 12, 2005
ser02rav4's Avatar
ser02rav4 is an unknown quantity at this point
honestly, the light output is not good.TYC rojectors dont work well with HID kits, you gonna have plenty dark spots etc. check out hidforum.com fYI.
you can only swap lenses from the TYC projectors into the real xenon projectors such as: audi 4-6 or tt, bmw.That will work great.
Old Mar 12, 2005
exactly, and the sonar halo projectors are alot worse. Almost no light on the ground and tons of glare
Old Mar 13, 2005
silverem2's Avatar
Light output is decent, speaking from a halogen term, but its no where gunna be near the amount of light that you COULD have if you put a true xenon projector in there.Typically the ones that fit best in there are the Valeo's.
Old Mar 13, 2005
silverem2's Avatar
All In all, YES they WILL work with Tyc's. JUST not as great as oem. But what else would you expect.
UltraHDGames
Jun 8, 2016 05:16 PM
TheRiddicles
Sep 21, 2015 03:43 PM
TheRiddicles
Sep 21, 2015 01:28 AM
MamaBear2015
Sep 4, 2015 09:04 PM
Voiceofid
Feb 3, 2002 03:54 PM
