Help ASAP
Old Feb 1, 2005
zwmichael's Avatar
zwmichael is an unknown quantity at this point
Exclamation Help ASAP
when wiring the reverse indiglo gauges, do you cut the red/black wire and then connect the red wire from the inverter? Or do you just strip the red/black wire enough to wrap the red inverter wire around it, then tape it? I got everything else ready i just need help with the wiring.
Old Feb 1, 2005
TeLLy's Avatar
Yes, it's an Acura EL
Strip, don't cut.
Old Feb 1, 2005
zwmichael's Avatar
aight, thanks man
