04 to 01-03 taillight harness conversion
Old Dec 30, 2004
Stocky's Avatar
Stocky is an unknown quantity at this point
How would I change an 04 coupe taillight harness to fit the 01-03 tail lights. A buddy of mine wants my atlezzas but he has an 04 civic and I'm pretty sure he'll have to modify it to fit. Anyone know?
I tried to just trade him for the 04's.
Old Dec 30, 2004
Mr.Modify's Avatar
so you want to change the 04's tailights to fit the 01-03's taillights right? just get the harness for it....
Old Dec 30, 2004
againifall's Avatar
Go Team Venture!
againifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of lightagainifall is a glorious beacon of light
just cut yer plugs off and swap them.. since you both will need what the other has.. its the free way to do it.. or you can get them from the stealership...
just be sure to label each plug with masking tape or something so you dont put them in the wrong place.. id suggest doing only one light at a time that way you can look at the other one to make sure you hooking them up right.. .. leave yerself an inch or two of wire attached to each plug.. then either solder them together or use wire connectors.. should only take you like an hour or so per car...
juicetayne
Sep 30, 2015 11:02 AM
Bruce2
Sep 27, 2015 08:45 PM
meicalnissyen
Sep 25, 2015 12:12 AM
AyyeeGeorgee
Sep 14, 2015 12:54 PM
Ultra Havoc
Sep 9, 2015 10:58 PM
