fog light wiring.
Old Nov 15, 2004
AggressiveAdam's Avatar
AggressiveAdam will become famous soon enoughAggressiveAdam will become famous soon enough
fog light wiring.
Just ordered some ebay fogs and got some questions about wiring
I want to be able to have my fogs on w/ my parking lights or full lights, how would this be acomplished?
I have HID's H4's with no high beams, can I have my high beam switch keep the headlights on (currently they turn off if you hit the highbeams which isnt good for HID's) and turn the fogs off? So that I can blink people when theres cops coming?
after doing all this could I still mount the button and have a manual on/off?
Appreciate the electrical advice in advance thanks!
thanks in advance you guys are awesome
Old Nov 16, 2004
anybody?
Old Nov 17, 2004
LiKEaFeRiO's Avatar
This is possible and its going to take some work.
On your HID wiring, are you using 2 or 3 prongs on the H4 plug?
I ask because I had hi/lo so its not the same.
Old Nov 17, 2004
not sure gonna pm impulse quickly to check, dont have the car nearby atm
Old Nov 17, 2004
Impulse is pretty sure its 2 prong
Old Nov 17, 2004
LiKEaFeRiO's Avatar
Okay then assuming that the unused 3rd prong is the positive for the high beams, the wiring should be pretty simple now.
You just need to tap power from the positive low beam wire to the high beam prong.
That'll keep your HIDs on when you high beam.
EDIT: When you have halogens, theres a certain point when you slowly flick back the switch, both filaments on the bulb gets power. I'm not sure how that'll affect the HID ballasts. Technically its getting twice the power so something might blow?
You need to tap the positive wire of the parking lights to your fogs to turn them on with your parking lights.
You'd have to tap the positive from the fogs to the positive on the headlights if you want the fog lights to turn off when you high beam.
The problem is how you are going to wire everything so nothing conflicts with each other.
Everything would need to be tapped after the foglight switch so you can turn them off completely.
Gonna go draw this out and see how it'll work.
Damn this is like one of those math logic questions that you need to solve or go crazy
Old Nov 20, 2004
awesome advice if you could draw it out id apprecaite it
Exterior
Nov 28, 2025 05:23 PM
XXLUV2EXCELR8XX
Dec 16, 2001 04:56 PM
LuvMyCivic
Dec 12, 2001 10:02 PM
klam
Nov 19, 2001 05:46 AM
klam
Nov 16, 2001 03:36 PM
