DIY - Bulbs for A/C, Air Recycle & Rear Defrost Buttons
Old Sep 28, 2004
castim's Avatar
castim is an unknown quantity at this point
Hi All,
I've been searching the forums for a DIY instructions to replace the bulb inside the "rear defrost" button on the center console for a '01 Civic LX. Can I just "pry" off the button w/o ruining the center console?
Thanks.
PS: Anyone have a scanned copy of the owner's manual? Its a @#$! pain trying to get it. The dealership never has it!!!
Old Sep 28, 2004
TeLLy's Avatar
Yes, it's an Acura EL
You've got to pull the whole center console out to access the button - otherwise you WILL break it. Besides, the A/C/defrost/recirc button assembly has TWO bulbs lighting the three icons. You have to get into the center console anyway to take it out. Once you have the console out (ie when installing a deck; the DIY is easily found) then you will see two screws holding it on to the center console. Actually now that I think about it, you can pull the offending bulbs without removing the module from the console. THey just twist in/out.
Old Sep 28, 2004
castim's Avatar
Thanks for the info. Looks like I have my work cut out for me. Its wierd though that there are only two bulbs. The a/c and recycle buttons come on ok but the rear defrost doesn't. I'll take advantage of removing the center console and re-adjusting my radio. I gotta get the radio dash kit. Any recommendations? I've saw this site but i need a recommendation --> http://www.autotoys.com/x/cust/produ...id=2155&cat=79
Old Sep 28, 2004
soundguy's Avatar
soundguy is an unknown quantity at this point
Check out the Metra kits. I just got one for my '03 and it looks good. You can pick one up at www.partsexpress.com
Old Sep 28, 2004
SiG's Avatar
SiG
i have a metra kit and am very pleased with the fitment
looks clean as stock
GolNat
Suspension DIY
May 12, 2022 06:49 AM
dinsum
May 28, 2015 09:30 PM
Pir8pete
165
Mar 6, 2009 05:16 PM
aZnVoYCe
Dec 7, 2001 12:41 AM
aZnVoYCe
Bolt-on Engine Performance
Nov 4, 2001 10:18 AM
